跳转到主内容
加入维修社区 - 创建账户
Led Lenser P2 BM Button Disassembly
你所需要的
    1. Led Lenser  P2 BM  Button Disassembly, Unscrew rear cap from the main housing: 步骤 1 中的图像 1,1
      • This is exactly how you would do it if you were changing the battery.
      询问修复机器人
      添加评论
    2. Led Lenser  P2 BM  Button Disassembly, Remove O-ring: 步骤 2 中的图像 1,1
      • Remove the small O-Ring, I used a plastic toothpick.
      询问修复机器人
      添加评论
    3. Led Lenser  P2 BM  Button Disassembly, Screw apart cap: 步骤 3 中的图像 1,2 Led Lenser  P2 BM  Button Disassembly, Screw apart cap: 步骤 3 中的图像 2,2
      • Now we will unscrew the aluminum cap from the plastic lower part. I used a pair of pliers to carefully hold the plastic part while unscrewing the aluminum part with my finger. Left-hand thread.
      询问修复机器人
      添加评论
    4. Led Lenser  P2 BM  Button Disassembly, Split housing: 步骤 4 中的图像 1,1
      • The plastic housing holds the actual button assembly and is made from two halves, These can carefully be pried apart wit a knife.
      询问修复机器人
      添加评论
    5. Led Lenser  P2 BM  Button Disassembly, Open button assembly: 步骤 5 中的图像 1,2 Led Lenser  P2 BM  Button Disassembly, Open button assembly: 步骤 5 中的图像 2,2
      • Button assembly mark in red circle. This is held together by 4 plastic "rivets" on the connector side, marked in green. Cafully cut these flush like in the picture.
      询问修复机器人
      添加评论
    6. Led Lenser  P2 BM  Button Disassembly, Separate the button. Clean and ispect: 步骤 6 中的图像 1,2 Led Lenser  P2 BM  Button Disassembly, Separate the button. Clean and ispect: 步骤 6 中的图像 2,2
      • You can then pry of the "lid" like in the third picture.
      • Carefully remove the inner springs and plungers. In the picture one small plunger is still in the top of the button.
      • In my case the problem was a tiny plastic "!shaving" inside the button blocking it from making a connection, Market with yellow arrow.
      询问修复机器人
      添加评论
    7. Led Lenser  P2 BM  Button Disassembly, Reassemble: 步骤 7 中的图像 1,1
      • Is reversed of disassembly but you don't need to glue the button together (the small plastic "rivets" are now broken) because the two part plastic housing will keep it together when assembled.
      • I have used it like this for years until the same problem happen again, so added some new images while fixing it again.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Hans
于04/25/16注册
430 声望
创作了2篇指南
3指南评论
Dear Hans.
I have used the same P3 LED for many years in bad switch condition.
Today I cleared this problem with your solution.
Very thank you & I'm appreciate to you.
DS2DDE
from Seoul, Korea.
김도욱 - 回复 分享
can you show how to take the front part apart?
Eric Secreve - 回复 分享
@ericsecreve Sadly I lost the light on an exercise, it's somewhere out in the woods now, all alone, cold and wet.
Hans - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 25
过去 30 天: 120
总计 4,826
