跳转到主内容
加入维修社区 - 创建账户
Leapfrog My Own Leaptop Battery Replacement Guide
你所需要的
    1. Leapfrog My Own Leaptop Battery Replacement Guide, Battery: 步骤 1 中的图像 1,1
      • Flip over device so that back portion of the device is facing you.
      询问修复机器人
      添加评论
    2. Leapfrog My Own Leaptop Battery Replacement Guide: 步骤 2 中的图像 1,1
      • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
      • Please note that the screw cannot be removed as it is attached to the battery cover.
      添加评论
    3. Leapfrog My Own Leaptop Battery Replacement Guide: 步骤 3 中的图像 1,2 Leapfrog My Own Leaptop Battery Replacement Guide: 步骤 3 中的图像 2,2
      • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
      • Remove the three AA batteries.
      • Note the direction of the batteries for when reassembling.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
USF Tampa, Team 14-6, Lacy Spring 2016 USF Tampa, Team 14-6, Lacy Spring 2016 的会员
USFT-LACY-S16S14G6
4 名成员
创作了15篇指南
1指南评论
Hi Jonathan! Your article is very helpful. But I have a big question now. I have opened the leaptop and see that membrane should be replaced. But where can I buy the membrane separately? Please help!
Alina Timchenko - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 85
总计 4,601
