简介
First, check to see if the volume is turned up to a reasonable level by using both the volume rocker on the side of the device and the digital volume bar in the settings menu. If the troubleshooting has not solved the issue, the volume rocker will need to be replaced in a few simple steps. Minimal tools will be needed for this guide.
你所需要的
Remove the four 2.5 mm Phillips #00 head screws from the circuit board near the top of the tablet.
另外一个人完成了本指南。
