简介
If your LG Xenon GR500 is not turning on from water exposure or drop impact, the issue may be resolved by replacing the motherboard. Handling the motherboard is considered a risky repair that can cause further damage to the device if not operated correctly, so proceed cautiously. This guide will show you how to remove and replace the motherboard carefully.
你所需要的
Use your index finger to pull the top of the battery out from the top center divot. Then pull the battery towards yourself to remove it from the compartment.
Use a Phillips #00 screwdriver to remove the six 2.4mm screws, which secure the back panel.
2等其他人完成本指南。
