跳转到主内容
加入维修社区 - 创建账户
LG VX8700 LCD Screen Replacement
你所需要的
  1. LG VX8700 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,2 LG VX8700 LCD Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Power the phone off.
    • Slide the back cover off using the release latch with your fingers to expose the battery.
    询问修复机器人
    添加评论
  2. LG VX8700 LCD Screen Replacement: 步骤 2 中的图像 1,2 LG VX8700 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, align the metal pins with those of the phone.
    询问修复机器人
    添加评论
  3. LG VX8700 LCD Screen Replacement, Front Bezel: 步骤 3 中的图像 1,1
    • Turn your phone around and open the flip phone. The screen is now facing you.
    • Locate the two grey rubber plugs on the bottom corners of the screen. These plugs cover up two screws.
    • Remove the two grey screw-covers.
    询问修复机器人
    添加评论
  4. LG VX8700 LCD Screen Replacement: 步骤 4 中的图像 1,2 LG VX8700 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Use the ejection tab at the top to remove the screen.
    • There is a gap between the case and the screen near the ear piece.
    • Insert the plastic opening tool in the gap and pry up the screen.
    • The plastic screen cover is glued onto the phone. It may be difficult to pry off.
    询问修复机器人
    添加评论
  5. LG VX8700 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Unscrew the four corners of the screen using 3.21mm screws to separate the top cover of the phone.
    询问修复机器人
    添加评论
  6. LG VX8700 LCD Screen Replacement: 步骤 6 中的图像 1,2 LG VX8700 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Turn your phone around. The battery side will be facing you.
    • Insert the plastic opening tool into the groove to remove the top cover of the phone.
    • Carefully open the cover.
    询问修复机器人
    添加评论
  7. LG VX8700 LCD Screen Replacement, Ear Piece: 步骤 7 中的图像 1,1
    • Locate the earpiece, which is the black component at the top with black and red wires.
    • Remove the component. Using a soldering iron, desolder the top ear piece.
    询问修复机器人
    添加评论
  8. LG VX8700 LCD Screen Replacement: 步骤 8 中的图像 1,2 LG VX8700 LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Using the plastic opening tool, lift the earpiece to remove it from the phone.
    询问修复机器人
    添加评论
  9. LG VX8700 LCD Screen Replacement, LCD Screen: 步骤 9 中的图像 1,1
    • Using a soldering iron, desolder the wires connected to the LCD board.
    询问修复机器人
    添加评论
  10. LG VX8700 LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Using the plastic opening tool, carefully disconnect the ribbon connecting the two pieces.
    询问修复机器人
    添加评论
  11. LG VX8700 LCD Screen Replacement: 步骤 11 中的图像 1,1
    • Remove the LCD screen.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 8-16, Maness Winter 2012 Cal Poly, Team 8-16, Maness Winter 2012 的会员
CPSU-MANESS-W12S8G16
4 名成员
创作了28篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 38
总计 2,087
