跳转到主内容
加入维修社区 - 创建账户
LG VX5600 Plastic Screen Protector Replacement
你所需要的
  1. LG VX5600 Plastic Screen Protector Replacement, Battery: 步骤 1 中的图像 1,2 LG VX5600 Plastic Screen Protector Replacement, Battery: 步骤 1 中的图像 2,2
    • Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
    • Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
    询问修复机器人
    添加评论
  2. LG VX5600 Plastic Screen Protector Replacement: 步骤 2 中的图像 1,2 LG VX5600 Plastic Screen Protector Replacement: 步骤 2 中的图像 2,2
    • Insert your finger into the small indentation above the battery.
    • Push down on the battery and pull it away from the phone; it will pop out.
    询问修复机器人
    添加评论
  3. LG VX5600 Plastic Screen Protector Replacement, Plastic Screen Protector: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to remove the two rubber covers found at the left and right corners below the inside screen.
    询问修复机器人
    添加评论
  4. LG VX5600 Plastic Screen Protector Replacement: 步骤 4 中的图像 1,1
    • Grasp the phone and rotate it 90 degrees counterclockwise for a better grip.
    • Unscrew the two 3.0-mm Phillips #000 screws, found under the rubber covers at the bottom left and right corners.
    • Some of the pictures show the bottom of the phone disassembled. It is unneccessary to disassemble the bottom of the phone for this guide.
    询问修复机器人
    添加评论
  5. LG VX5600 Plastic Screen Protector Replacement: 步骤 5 中的图像 1,2 LG VX5600 Plastic Screen Protector Replacement: 步骤 5 中的图像 2,2
    • Hold the opened phone upright.
    • Use the spudger to pry around the edges of the phone and detach the tabs.
    • Make sure all the tabs around the grey cover are detached. They are located on the top and on both sides of the screen.
    询问修复机器人
    添加评论
  6. LG VX5600 Plastic Screen Protector Replacement: 步骤 6 中的图像 1,1
    • Use your finger to lift up the grey plastic cover.
    • Use the tweezers to grasp the plastic screen, and pull the plastic screen protector up and out of the phone.
    • The plastic screen protector is adhered with glue to the back of the phone, so a little force is required to remove it.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 34
总计 811
