跳转到主内容
加入维修社区 - 创建账户
LG VX5600 Keypad Replacement
你所需要的
  1. LG VX5600 Keypad Replacement, Battery: 步骤 1 中的图像 1,2 LG VX5600 Keypad Replacement, Battery: 步骤 1 中的图像 2,2
    • Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
    • Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
    询问修复机器人
    添加评论
  2. LG VX5600 Keypad Replacement: 步骤 2 中的图像 1,2 LG VX5600 Keypad Replacement: 步骤 2 中的图像 2,2
    • Insert your finger into the small indentation above the battery.
    • Push down on the battery and pull it away from the phone; it will pop out.
    询问修复机器人
    添加评论
  3. LG VX5600 Keypad Replacement, Keypad: 步骤 3 中的图像 1,2 LG VX5600 Keypad Replacement, Keypad: 步骤 3 中的图像 2,2
    • Grasp the edges of the phone with one hand.
    • Unscrew the six 5.0-mm Phillips #000 screws located around the outside of the back panel of the phone.
    • The screws are tight, so you have to use a little force when unscrewing them.
    询问修复机器人
    添加评论
  4. LG VX5600 Keypad Replacement: 步骤 4 中的图像 1,1
    • Insert the spudger into the tab at the top of the back panel and push to release the panel.
    • The back panel will then lift away from the rest of the phone.
    询问修复机器人
    添加评论
  5. LG VX5600 Keypad Replacement: 步骤 5 中的图像 1,2 LG VX5600 Keypad Replacement: 步骤 5 中的图像 2,2
    • Flip the phone open with the back side still facing you.
    • Grasping the phone on the sides, use your fingers to push up on the keypad and motherboard until they release from the phone casing.
    • When you do this the plastic camera button will pop out. It is not directly attached to anything. Make sure to save it for reassembly because it must be placed back on its tab at the side with the camera icon is facing right side up to work correctly
    询问修复机器人
    添加评论
  6. LG VX5600 Keypad Replacement: 步骤 6 中的图像 1,2 LG VX5600 Keypad Replacement: 步骤 6 中的图像 2,2
    • Lift up the motherboard.
    询问修复机器人
    添加评论
  7. LG VX5600 Keypad Replacement: 步骤 7 中的图像 1,2 LG VX5600 Keypad Replacement: 步骤 7 中的图像 2,2
    • Grasp the keypad and lift it up and out of the phone.
    • An image of the front of the keypad and phone is shown.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 31
总计 826
