跳转到主内容
加入维修社区 - 创建账户
LG V10 Dual Front Cameras Replacement
你所需要的
  1. LG V10 Dual Front Cameras Replacement, Battery: 步骤 1 中的图像 1,1
    • Wedge the flat end of the plastic spudger, or the tip of your finger, in between the back cover and the LG V10’s charging port.
    • If using a spudger, it should not be in the charging port, but between the metal lining of the charging port and the back cover.
    • Carefully lift up on the spudger or with your finger so that the back cover pops up. The rest of the back cover should easily come off by sliding a finger or spudger under the back cover and around the sides.
    询问修复机器人
    添加评论
  2. LG V10 Dual Front Cameras Replacement: 步骤 2 中的图像 1,2 LG V10 Dual Front Cameras Replacement: 步骤 2 中的图像 2,2
    • There’s an impression next to the battery for the user to use their finger to pry the battery out; pry the battery out using your finger or the flat end of the spudger.
    询问修复机器人
    添加评论
  3. LG V10 Dual Front Cameras Replacement, Dual Front Cameras: 步骤 3 中的图像 1,3 LG V10 Dual Front Cameras Replacement, Dual Front Cameras: 步骤 3 中的图像 2,3 LG V10 Dual Front Cameras Replacement, Dual Front Cameras: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Using a screwdriver with a J000 Phillips bit, remove fourteen 3.175 mm screws.
    • Using a plastic opening tool, pry part of the panel up starting from the sides of the battery slot.
    • Use plastic tweezers to release the rest of the panel from plastic bits holding it in place and pry the panel up around the sides surrounding the fingerprint sensor and camera lens.
    询问修复机器人
    添加评论
  4. LG V10 Dual Front Cameras Replacement: 步骤 4 中的图像 1,2 LG V10 Dual Front Cameras Replacement: 步骤 4 中的图像 2,2
    • Using the flat end of a plastic spudger or a plastic opening tool, wedge it under the front cameras’ motherboard connection and disconnect it.
    询问修复机器人
    添加评论
结论
After replacing the dual front cameras, follow these instructions in reverse order to reassemble the LG V10.
取消:我没有完成这个指南。
Joseph
于09/25/17注册
1,005 声望
创作了4篇指南
团队
USF Tampa, Team S16-G3, Eyestone Fall 2017 USF Tampa, Team S16-G3, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S16G3
2 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 899
