跳转到主内容
加入维修社区 - 创建账户
LG Tribute Motherboard Replacement
你所需要的
  1. LG Tribute Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 LG Tribute Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Use the plastic opening tool to pry off the back cover.
    询问修复机器人
    添加评论
  2. LG Tribute Motherboard Replacement: 步骤 2 中的图像 1,1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
    询问修复机器人
    添加评论
  3. LG Tribute Motherboard Replacement, Mid-panel: 步骤 3 中的图像 1,2 LG Tribute Motherboard Replacement, Mid-panel: 步骤 3 中的图像 2,2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
    询问修复机器人
    添加评论
  4. LG Tribute Motherboard Replacement: 步骤 4 中的图像 1,2 LG Tribute Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
    询问修复机器人
    添加评论
  5. LG Tribute Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to disconnect the touchscreen from the motherboard.
    • The motherboard will be completely free from the front panel after this step.
    询问修复机器人
    添加评论
  6. LG Tribute Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,3 LG Tribute Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,3 LG Tribute Motherboard Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Remove SIM card by sliding it out of its housing.
    • Remove the front-facing camera using a plastic opening tool.
    • Remove rear-facing camera using a plastic opening tool.
    • Connect these three components to the new motherboard.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
2指南评论
ممكن تشريح بوردة lg ls660
nabeel - 回复 分享
For those that find this guide and are looking to dissasemble an lg tribute 2, Make sure to remove your sim card before romoving the cover that has screws. other than that its the same, but i spent a half hour removing my cover carefully just to find out the sd card had held the cover and motherboard togeather, causing Added risk of damage.
Christian Rolfe - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 45
总计 4,300
