跳转到主内容
加入维修社区 - 创建账户
LG Stylo 2 Plus Screen Replacement
你所需要的
    1. LG Stylo 2 Plus Screen Replacement, Rear Case: 步骤 1 中的图像 1,3 LG Stylo 2 Plus Screen Replacement, Rear Case: 步骤 1 中的图像 2,3 LG Stylo 2 Plus Screen Replacement, Rear Case: 步骤 1 中的图像 3,3
      • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
      • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
      询问修复机器人
      添加评论
    1. LG Stylo 2 Plus Screen Replacement, Battery: 步骤 2 中的图像 1,3 LG Stylo 2 Plus Screen Replacement, Battery: 步骤 2 中的图像 2,3 LG Stylo 2 Plus Screen Replacement, Battery: 步骤 2 中的图像 3,3
      • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
      • Firmly grasp the battery and remove from the phone.
      询问修复机器人
      添加评论
    1. LG Stylo 2 Plus Screen Replacement, Mid-Frame: 步骤 3 中的图像 1,2 LG Stylo 2 Plus Screen Replacement, Mid-Frame: 步骤 3 中的图像 2,2
      • Using the JIS #000 screwdriver, remove the eleven 4mm screws around the mid-frame.
      询问修复机器人
      添加评论
    2. LG Stylo 2 Plus Screen Replacement: 步骤 4 中的图像 1,2 LG Stylo 2 Plus Screen Replacement: 步骤 4 中的图像 2,2
      • Insert the metal spudger in the dimple at the base of the cover.
      • Pry upward, removing the mid-frame from the phone.
      询问修复机器人
      添加评论
    1. LG Stylo 2 Plus Screen Replacement, Screen: 步骤 5 中的图像 1,1
      在这个步骤中使用的工具:
      • Using tweezers, lift up on the ribbon connector and separate the rear camera from the mainboard.
      • Remove the rear camera from the housing by using fingers or tweezers and gently pry upwards.
      询问修复机器人
      添加评论
    2. LG Stylo 2 Plus Screen Replacement: 步骤 6 中的图像 1,1
      • Lift up on the ribbon cable connection and separate the front camera from the mainboard.
      • Remove the front camera from its housing by lifting up on the rubber surrounding the camera.
      询问修复机器人
      添加评论
    3. LG Stylo 2 Plus Screen Replacement: 步骤 7 中的图像 1,1
      • Locate the ribbon cable connecting the screen to the mainboard.
      • Separate the two by prying up on the connector.
      询问修复机器人
      添加评论
    4. LG Stylo 2 Plus Screen Replacement: 步骤 8 中的图像 1,2 LG Stylo 2 Plus Screen Replacement: 步骤 8 中的图像 2,2
      • With the mainboard now free, carefully remove it and set it to the side.
      询问修复机器人
      添加评论
    5. LG Stylo 2 Plus Screen Replacement: 步骤 9 中的图像 1,1
      • To prepare the phone for heat you need to remove the audio jack.
      • This can be done using tweezers or fingers, and prying upwards.
      询问修复机器人
      添加评论
    6. LG Stylo 2 Plus Screen Replacement: 步骤 10 中的图像 1,1
      • Still using the tweezers, remove the front speaker unit by lifting up on the ribbon cable connector.
      询问修复机器人
      添加评论
    7. LG Stylo 2 Plus Screen Replacement: 步骤 11 中的图像 1,1
      • The buzzer also needs to be removed and is secured by a strong adhesive.
      • Remove the buzzer by getting the tweezers under the adhesive, and carefully prying upwards.
      询问修复机器人
      添加评论
    8. LG Stylo 2 Plus Screen Replacement: 步骤 12 中的图像 1,3 LG Stylo 2 Plus Screen Replacement: 步骤 12 中的图像 2,3 LG Stylo 2 Plus Screen Replacement: 步骤 12 中的图像 3,3
      • Using tweezers, gently pull upwards on one edge of the adhesive tape.
      • Carefully pull the tape back until the whole ribbon cable is exposed.
      询问修复机器人
      添加评论
    9. LG Stylo 2 Plus Screen Replacement: 步骤 13 中的图像 1,3 LG Stylo 2 Plus Screen Replacement: 步骤 13 中的图像 2,3 LG Stylo 2 Plus Screen Replacement: 步骤 13 中的图像 3,3
      • Remember to put on your safety glasses if you have not already. Glass, and shattered glass especially, can be dangerous if proper eye protection is not worn.
      • Briefly run the heat gun on a low setting around the outside edge of the screen to warm up the adhesive keeping the phone in place.
      • Keep heat gun on a low setting, and keep the point you are heating moving. Do not hold the heat gun in one spot for long.
      • Work an iFixit opening tool under the lip of the screen and pry upwards carefully.
      • Once you are able to work the screen up around the edge of the device, pull the ribbon cable out of the phone through the thin slot at the bottom of the phone.
      询问修复机器人
      添加评论
结论
To reassemble your device, apply the new screen to the phone frame, and follow these instructions in reverse order.
取消:我没有完成这个指南。
3等其他人完成本指南。
Zach Lowe
于04/22/19注册
205 声望
撰写一个指南
团队
UW Tacoma, Team S1-G3, Cardinal Spring 2019 UW Tacoma, Team S1-G3, Cardinal Spring 2019 的会员
UWT-CARDINAL-S19S1G3
4 名成员
创作了56篇指南
1指南评论
Good afternoon, I greet you from Guatemla, I need your help, could you provide me with the schematic diagram of the LG MS550 phone
sergio isaias vicente coc - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 19
总计 1,002
