简介
This guide will walk you through the process of replacing a battery in an LG Phoenix 2. A battery replacement may be needed if the phone loses charge faster than it did when it was new. A battery replacement may also be needed if the phone only works when it is plugged in and does not hold a charge at all.
The battery model used in this phone is a BL-46ZH battery.
Place a fingernail in the notch at the bottom edge of the phone.
Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
3等其他人完成本指南。
