简介
Got a cracked or busted screen on your LG Optimus L7 P705? No worries. This guide will help you swap out the display and get your phone looking (and working) like new again. We’ll walk you through each step, from popping off the back cover to removing the screen, using just a few tools.
Before you begin, ensure the phone is powered off and that you're working on a clean, safe surface.
你所需要的
Use a plastic opening tool to gently pry the back cover away from the phone by inserting it into the seam around the edges.
Once the cover is off, remove the battery and SIM card.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
8等其他人完成本指南。
