跳转到主内容
加入维修社区 - 创建账户
LG Optimus F3 Charging port unit Replacement
你所需要的
  1. LG Optimus F3 Charging port unit  Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Turn the device so that the back faces up.
    • It is easiest to open the case near the charging port located at the bottom of the phone.
    • Remove the back case by pushing up on the back and pulling down on the face as illustrated in the image.
    询问修复机器人
    添加评论
  2. LG Optimus F3 Charging port unit  Replacement: 步骤 2 中的图像 1,1
    • With back case removed, the battery is visible. The battery is the large square object.
    • Remove the battery by flipping the bottom edge upward to separate the battery from the case.
    询问修复机器人
    添加评论
  3. LG Optimus F3 Charging port unit  Replacement: 步骤 3 中的图像 1,1
    • Remove 10 1.0 mm screws located on the back of the device.
    • Refer to the outlined locations in the image for the screws.
    询问修复机器人
    添加评论
  4. LG Optimus F3 Charging port unit  Replacement: 步骤 4 中的图像 1,1
    • Use the plastic opening tool to separate the inner case from the device.
    • Wedge the plastic opening tool between the case.
    • Wiggle the tool and use leverage to pry the case apart.
    询问修复机器人
    添加评论
  5. LG Optimus F3 Charging port unit  Replacement: 步骤 5 中的图像 1,1
    • The camera unit is located at the top left of the phone. The camera is a silver box with a black lens. The image pin points where the camera is on the motherboard.
    • Use the plastic opening tool to separate the camera from the motherboard.
    • Wedge the plastic tool between the camera and the motherboard to loosen the camera unit.
    询问修复机器人
    添加评论
  6. LG Optimus F3 Charging port unit  Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Use a pair of tweezers to disconnect and remove the rear facing camera.
    询问修复机器人
    添加评论
  7. LG Optimus F3 Charging port unit  Replacement: 步骤 7 中的图像 1,1
    • Use the plastic opening tool to separate the sim card and the memory card connector from the motherboard.
    • Note that the sim card and the memory card connector are one unit.
    • Wedge the plastic tool to lift up the sim-memory unit from the motherboard.
    询问修复机器人
    添加评论
  8. LG Optimus F3 Charging port unit  Replacement: 步骤 8 中的图像 1,1
    • Use the plastic opening tool to remove the charging port unit.
    • Wedge the plastic opening tool between the charging port unit and the motherboard to separate the port.
    询问修复机器人
    添加评论
  9. LG Optimus F3 Charging port unit  Replacement: 步骤 9 中的图像 1,1
    • Use the plastic opening tool to remove the motherboard located directly above the battery encasement.
    • The motherboard is an L-shaped unit above and to the left of the battery encasement.
    • Wedge the plastic opening tool between the circuit board and the motherboard to separate the unit.
    询问修复机器人
    添加评论
  10. LG Optimus F3 Charging port unit  Replacement, Charging port unit: 步骤 10 中的图像 1,1
    • Remove one 1.0 mm screw.
    询问修复机器人
    添加评论
  11. LG Optimus F3 Charging port unit  Replacement: 步骤 11 中的图像 1,1
    • Use a plastic opening tool to remove front glass protector.
    询问修复机器人
    添加评论
  12. LG Optimus F3 Charging port unit  Replacement: 步骤 12 中的图像 1,1
    • Use the plastic opening tool to remove front glass cover carefully. Try not to break the connector.
    询问修复机器人
    添加评论
  13. LG Optimus F3 Charging port unit  Replacement: 步骤 13 中的图像 1,1
    • Remove the front facing camera.
    询问修复机器人
    添加评论
  14. LG Optimus F3 Charging port unit  Replacement: 步骤 14 中的图像 1,1
    • Use the plastic opening tool to carefully remove the home button board. It is attached with double-sided tape.
    询问修复机器人
    添加评论
  15. LG Optimus F3 Charging port unit  Replacement: 步骤 15 中的图像 1,1
    询问修复机器人
    添加评论
  16. LG Optimus F3 Charging port unit  Replacement: 步骤 16 中的图像 1,1
    • You are all set.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
UMass Dartmouth, Team 1-5, Miles Fall 2015 UMass Dartmouth, Team 1-5, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 29
总计 935
