跳转到主内容
加入维修社区 - 创建账户
LG Optimus 3D Motherboard Replacement
你所需要的
    1. LG Optimus 3D Motherboard Replacement, Back Cover Removal: 步骤 1 中的图像 1,2 LG Optimus 3D Motherboard Replacement, Back Cover Removal: 步骤 1 中的图像 2,2
      • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
      询问修复机器人
      添加评论
    2. LG Optimus 3D Motherboard Replacement, Battery Removal: 步骤 2 中的图像 1,3 LG Optimus 3D Motherboard Replacement, Battery Removal: 步骤 2 中的图像 2,3 LG Optimus 3D Motherboard Replacement, Battery Removal: 步骤 2 中的图像 3,3
      • The battery is the large black rectangle towards the bottom half of the phone.
      • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
      询问修复机器人
      添加评论
    1. LG Optimus 3D Motherboard Replacement, Screw Removal: 步骤 3 中的图像 1,2 LG Optimus 3D Motherboard Replacement, Screw Removal: 步骤 3 中的图像 2,2
      • Remove 9 screws from the phone. The locations of these screws are circled in the picture.
      • 5.5mm length PH00 screws
      • 4mm length PH00 screws
      询问修复机器人
      添加评论
    2. LG Optimus 3D Motherboard Replacement, Bottom Cover Removal: 步骤 4 中的图像 1,2 LG Optimus 3D Motherboard Replacement, Bottom Cover Removal: 步骤 4 中的图像 2,2
      • Gently pull down on the bottom cover to remove it.
      询问修复机器人
      添加评论
    3. LG Optimus 3D Motherboard Replacement, Mid-Cover Bezel Removal: 步骤 5 中的图像 1,3 LG Optimus 3D Motherboard Replacement, Mid-Cover Bezel Removal: 步骤 5 中的图像 2,3 LG Optimus 3D Motherboard Replacement, Mid-Cover Bezel Removal: 步骤 5 中的图像 3,3
      • Using a plastic opening tool, gently pry around the perimeter of the device.
      • The ribbons behind the buttons and ports are very delicate. Make sure you do not run your plastic opening tool too deep into the bezel, as you could damage them.
      • The button covers rest under the Mid-Cover Bezel. Remove them and set aside.
      添加评论
    4. LG Optimus 3D Motherboard Replacement, Ribbon Cable Disconnection: 步骤 6 中的图像 1,2 LG Optimus 3D Motherboard Replacement, Ribbon Cable Disconnection: 步骤 6 中的图像 2,2
      • Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board.
      询问修复机器人
      添加评论
    5. LG Optimus 3D Motherboard Replacement, Adhesive Loosening: 步骤 7 中的图像 1,1
      • Use a hair-dryer on high, or a heat-gun on low to heat the device and loosen the adhesive which holds down the SD/SIM Card Board.
      • Evenly heat the device in short intervals for about one minute.
      • Do not heat the device for more than 30 seconds at a time to prevent over-heating.
      添加评论
    6. LG Optimus 3D Motherboard Replacement, SD/SIM Card Board Removal: 步骤 8 中的图像 1,3 LG Optimus 3D Motherboard Replacement, SD/SIM Card Board Removal: 步骤 8 中的图像 2,3 LG Optimus 3D Motherboard Replacement, SD/SIM Card Board Removal: 步骤 8 中的图像 3,3
      • Gently pry the board up to release it from the now soft adhesive. Make sure you pry up the little tab connected to the camera unit as well.
      • If the board is too difficult to separate than more heating may be required.
      询问修复机器人
      添加评论
    1. LG Optimus 3D Motherboard Replacement, Disconnect Ribbon Cables: 步骤 9 中的图像 1,2 LG Optimus 3D Motherboard Replacement, Disconnect Ribbon Cables: 步骤 9 中的图像 2,2
      • Using a spudger or plastic opening tool, gently lift the ribbon cables connected to the motherboard.
      • The button tabs, highlighted in orange, are held in with a light adhesive. Gently lift them out of the body of the phone with a spudger.
      询问修复机器人
      添加评论
    2. LG Optimus 3D Motherboard Replacement, Disconnect Antenna: 步骤 10 中的图像 1,2 LG Optimus 3D Motherboard Replacement, Disconnect Antenna: 步骤 10 中的图像 2,2
      • Remove the antenna cable by disconnecting both ends.
      • One end connects to the motherboard and the other connects near bottom of the phone.
      询问修复机器人
      添加评论
    3. LG Optimus 3D Motherboard Replacement, Remove Motherboard: 步骤 11 中的图像 1,2 LG Optimus 3D Motherboard Replacement, Remove Motherboard: 步骤 11 中的图像 2,2
      • Using a spudger gently lift the motherboard assembly out of the case.
      • Make sure the motherboard does not get snagged on the camera's ribbon cable.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
USF Tampa, Team 10-6, Brown Fall 2014 USF Tampa, Team 10-6, Brown Fall 2014 的会员
USFT-BROWN-F14S10G6
3 名成员
创作了54篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 42
总计 1,878
