跳转到主内容
加入维修社区 - 创建账户
LG Leon LTE SIM Card Replacement
你所需要的
    1. LG Leon LTE SIM Card Replacement, SIM card: 步骤 1 中的图像 1,2 LG Leon LTE SIM Card Replacement, SIM card: 步骤 1 中的图像 2,2
      • First, make sure to turn the phone over so that you are viewing the backside. The battery is located inside the back of the phone.
      询问修复机器人
      添加评论
    2. LG Leon LTE SIM Card Replacement: 步骤 2 中的图像 1,3 LG Leon LTE SIM Card Replacement: 步骤 2 中的图像 2,3 LG Leon LTE SIM Card Replacement: 步骤 2 中的图像 3,3
      • Second, using your opening tool in an upward direction, carefully pry the back of the phone open at the incision area. This can be found at the bottom of the phone. You will now have access to the battery.
      • Once you have access to the battery, remove it carefully so that you can get to the SIM card. The SIM card can be seen in the third image.
      • Battery removal is not pictured.
      询问修复机器人
      添加评论
    3. LG Leon LTE SIM Card Replacement: 步骤 3 中的图像 1,2 LG Leon LTE SIM Card Replacement: 步骤 3 中的图像 2,2
      • Once the SIM card is accessible, slide it from the SIM holder as demonstrated. Apply a downward force in an outward motion.
      • Slight force will be needed when pulling the SIM card from the SIM card holder.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
1指南评论
You should do one on how to replace the SIM card tray
Wolfgang 847 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 41
总计 1,336
