跳转到主内容
加入维修社区 - 创建账户
LG L1200 Outer LCD Screen Replacement
你所需要的
    1. LG L1200 Outer LCD Screen Replacement, Inner LCD Screen: 步骤 1 中的图像 1,1
      • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
      • Flip open the phone and locate the four screw covers.
      询问修复机器人
      添加评论
    2. LG L1200 Outer LCD Screen Replacement: 步骤 2 中的图像 1,1
      • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
      询问修复机器人
      添加评论
    3. LG L1200 Outer LCD Screen Replacement: 步骤 3 中的图像 1,1
      • Using a T6 Torx screwdriver, remove all four screws.
      询问修复机器人
      添加评论
    4. LG L1200 Outer LCD Screen Replacement: 步骤 4 中的图像 1,3 LG L1200 Outer LCD Screen Replacement: 步骤 4 中的图像 2,3 LG L1200 Outer LCD Screen Replacement: 步骤 4 中的图像 3,3
      • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
      • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
      询问修复机器人
      添加评论
    5. LG L1200 Outer LCD Screen Replacement: 步骤 5 中的图像 1,2 LG L1200 Outer LCD Screen Replacement: 步骤 5 中的图像 2,2
      • Pull the inner screen cover towards you and up in order to separate it from the front cover.
      询问修复机器人
      添加评论
    6. LG L1200 Outer LCD Screen Replacement: 步骤 6 中的图像 1,1
      • Remove the tape from the bottom of the LCD screen.
      询问修复机器人
      添加评论
    7. LG L1200 Outer LCD Screen Replacement: 步骤 7 中的图像 1,3 LG L1200 Outer LCD Screen Replacement: 步骤 7 中的图像 2,3 LG L1200 Outer LCD Screen Replacement: 步骤 7 中的图像 3,3
      • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
      询问修复机器人
      添加评论
    8. LG L1200 Outer LCD Screen Replacement: 步骤 8 中的图像 1,3 LG L1200 Outer LCD Screen Replacement: 步骤 8 中的图像 2,3 LG L1200 Outer LCD Screen Replacement: 步骤 8 中的图像 3,3
      • Flip the screen over so that you can see the outer LCD screen and the circuit board.
      • Insert spudger in the bottom right corner.
      • Lift up and move the spudger across the bottom.
      • The third photo is rotated 180 degrees.
      询问修复机器人
      添加评论
    9. LG L1200 Outer LCD Screen Replacement: 步骤 9 中的图像 1,2 LG L1200 Outer LCD Screen Replacement: 步骤 9 中的图像 2,2
      • Use the pointy side of the spudger to peel off the interior tape.
      • Flip the assembly over and peel the circuit board from the screen.
      询问修复机器人
      添加评论
    10. LG L1200 Outer LCD Screen Replacement: 步骤 10 中的图像 1,2 LG L1200 Outer LCD Screen Replacement: 步骤 10 中的图像 2,2
      • Use the spudger to remove the LCD screen from its backing.
      询问修复机器人
      添加评论
    1. LG L1200 Outer LCD Screen Replacement, Outer LCD Screen: 步骤 11 中的图像 1,1
      • The outer LCD screen can be found on the circuit board, which is attached to the back of the inner LCD screen.
      询问修复机器人
      添加评论
    2. LG L1200 Outer LCD Screen Replacement: 步骤 12 中的图像 1,2 LG L1200 Outer LCD Screen Replacement: 步骤 12 中的图像 2,2
      • Use an IPod opening tool to carefully lift the screen from its backing.
      • Use your finger to pull the screen forward.
      询问修复机器人
      添加评论
    3. LG L1200 Outer LCD Screen Replacement: 步骤 13 中的图像 1,2 LG L1200 Outer LCD Screen Replacement: 步骤 13 中的图像 2,2
      • Pull the screen and the tape ribbon off the circuit board.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 6-14, Maness Spring 2010 Cal Poly, Team 6-14, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G14
4 名成员
创作了56篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 1,219
