跳转到主内容
加入维修社区 - 创建账户
LG K7 T-Mobile Rear Phone Camera Replacement
你所需要的
  1. LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: 步骤 1 中的图像 1,2 LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the LG K7 over so that the back of the phone is facing up.
    • Locate the small notch on the bottom left side of the phone.
    添加评论
  2. LG K7 T-Mobile Rear Phone  Camera Replacement: 步骤 2 中的图像 1,1
    • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
    询问修复机器人
    添加评论
  3. LG K7 T-Mobile Rear Phone  Camera Replacement: 步骤 3 中的图像 1,1
    • Remove the battery.
    添加评论
  4. LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: 步骤 4 中的图像 1,2 LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: 步骤 4 中的图像 2,2
    • Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
    • Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
    询问修复机器人
    添加评论
  5. LG K7 T-Mobile Rear Phone  Camera Replacement: 步骤 5 中的图像 1,3 LG K7 T-Mobile Rear Phone  Camera Replacement: 步骤 5 中的图像 2,3 LG K7 T-Mobile Rear Phone  Camera Replacement: 步骤 5 中的图像 3,3
    • Turn the phone over so the screen is facing up
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
    询问修复机器人
    添加评论
  6. LG K7 T-Mobile Rear Phone  Camera Replacement: 步骤 6 中的图像 1,3 LG K7 T-Mobile Rear Phone  Camera Replacement: 步骤 6 中的图像 2,3 LG K7 T-Mobile Rear Phone  Camera Replacement: 步骤 6 中的图像 3,3
    • Locate the ribbon cable that holds the camera's ribbon cable in place.
    • Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the camera ribbon you just released pull upwards and the camera should release from the case.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Salem Jean
于09/28/17注册
216 声望
撰写一个指南
团队
USF Tampa, Team S2-G5, Nance Fall 2017 USF Tampa, Team S2-G5, Nance Fall 2017 的会员
USFT-NANCE-F17S2G5
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 30
总计 803
