跳转到主内容
加入维修社区 - 创建账户
LG K20 PLUS Display Assembly Replacement
你所需要的
    1. LG K20 PLUS Display Assembly Replacement, Remove the back cover and battery: 步骤 1 中的图像 1,2 LG K20 PLUS Display Assembly Replacement, Remove the back cover and battery: 步骤 1 中的图像 2,2
      • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
      • Lift battery up here
      添加评论
    1. LG K20 PLUS Display Assembly Replacement, Midframe: 步骤 2 中的图像 1,1
      • Remove 11 Philips screws.
      询问修复机器人
      添加评论
    2. LG K20 PLUS Display Assembly Replacement: 步骤 3 中的图像 1,2 LG K20 PLUS Display Assembly Replacement: 步骤 3 中的图像 2,2
      • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
      • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
      • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
      询问修复机器人
      添加评论
    1. LG K20 PLUS Display Assembly Replacement, Rear-Facing Camera: 步骤 4 中的图像 1,1
      在这个步骤中使用的工具:
      Halberd Spudger
      $2.99
      • Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
      询问修复机器人
      添加评论
    1. LG K20 PLUS Display Assembly Replacement, Front Camera: 步骤 5 中的图像 1,1
      在这个步骤中使用的工具:
      Halberd Spudger
      $2.99
      • Use an opening pick or a Halberd spudger to disconnect the front camera flex from its socket on the motherboard.
      • The front camera is held in by adhesive. Carefully pry between the camera and its bracket on the frame of the phone to remove it.
      • If you're having difficulty removing the front-facing camera, remove the motherboard to make more room.
      询问修复机器人
      添加评论
    1. LG K20 PLUS Display Assembly Replacement, Motherboard Removal: 步骤 6 中的图像 1,1
      • Using the tip of a Halberd spudger or an opening pick, disconnect the display flex cable from its socket on the motherboard.
      • Starting from the bottom, insert an opening pick between the motherboard and frame and lever apart.
      • Be careful not to break the long section of the motherboard.
      • The top part of the motherboard is lightly adhered to the frame.
      • After the motherboard is removed, compare the original and replacement part. Some components may already be installed on the replacement display assembly.
      添加评论
    1. LG K20 PLUS Display Assembly Replacement, Volume Buttons Removal: 步骤 7 中的图像 1,1
      • The volume button assembly is held onto the frame with fragile plastic tabs.
      • Use the tip of a spudger or similar tool to gently pry the plastic tabs upwards and outwards.
      询问修复机器人
      添加评论
    1. LG K20 PLUS Display Assembly Replacement, Removing the vibrator: 步骤 8 中的图像 1,1
      • The vibrator motor is held in with strong adhesive.
      • Insert the tip of a metal spudger on the right side of the vibrator motor and pry it upwards.
      询问修复机器人
      添加评论
    1. LG K20 PLUS Display Assembly Replacement, Ear Speaker Removal: 步骤 9 中的图像 1,1
      • The flex cable and speaker are held in with adhesive. Use heat to soften the adhesive.
      • Carefully insert a Jimmy between the flex cable and the frame and detach the cable from the adhesive.
      • Then use the tip of a metal spudger to continue carefully prying the ear speaker up out of its housing.
      添加评论
    1. LG K20 PLUS Display Assembly Replacement, Separating the Headphone Jack: 步骤 10 中的图像 1,2 LG K20 PLUS Display Assembly Replacement, Separating the Headphone Jack: 步骤 10 中的图像 2,2
      • The headphone jack is adhered to the frame, and its flex cable is adhered to the frame and the strip of Kapton tape.
      • Use heat to soften the adhesive, then insert an opening pick here to separate the flex cable from the frame.
      • Use an opening pick to pry around the headphone jack to separate it from the adhesive in its housing.
      • If you're only replacing the headphone jack, peel it off of the Kapton tape. If you're replacing the display, go to the next step.
      询问修复机器人
      添加评论
    1. LG K20 PLUS Display Assembly Replacement, Transfer of Kapton tape and headphone jack: 步骤 11 中的图像 1,1
      • For best results, transfer this piece of Kapton tape to the new display assembly, if necessary.
      • It is adhered under the bottom tab of the antenna contact cable. Use heat to soften the adhesive, then use an opening pick to gently pry the contact upwards.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
10等其他人完成本指南。
Patrick
于05/14/14注册
6,782 声望
创作了21篇指南
5指南评论
You forgot to mention that the volume button flex needs to be transferred from the original unit.
Jeana Morales - 回复 分享
Hi! my parent drop the LG K20 and now the charger cable is loose, and the volume buttons are in the same frame, the phone is not charging. I need that frame. that’s what my cousin told me ¿can I buy that part?
Roberto lopez - 回复 分享
Thank you great job!!
Podia ser em português.
ferreiraclaudemir.33 - 回复 分享
My screen is jumping around. How do I fix
Todd Carlson - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 42
总计 4,920
