跳转到主内容
加入维修社区 - 创建账户
LG Incite Touch Screen Replacement
你所需要的
    1. LG Incite Touch Screen Replacement, Battery: 步骤 1 中的图像 1,1
      • Hold the phone camera-side up and locate the rear cover.
      询问修复机器人
      添加评论
    2. LG Incite Touch Screen Replacement: 步骤 2 中的图像 1,1
      • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
      询问修复机器人
      添加评论
    3. LG Incite Touch Screen Replacement: 步骤 3 中的图像 1,1
      • Place the plastic opening tool in the small slot below and to the left of the battery.
      • Pry the battery upward to remove it.
      询问修复机器人
      添加评论
    1. LG Incite Touch Screen Replacement, Back Panel: 步骤 4 中的图像 1,1
      • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
      询问修复机器人
      添加评论
    2. LG Incite Touch Screen Replacement: 步骤 5 中的图像 1,1
      • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
      • Gently move the tool around the perimeter of the screen to separate it from the body.
      • You should not completely separate the screen from the device in this step.
      询问修复机器人
      添加评论
    3. LG Incite Touch Screen Replacement: 步骤 6 中的图像 1,1
      • Flip the device over so the battery compartment faces up.
      • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
      • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
      • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
      询问修复机器人
      添加评论
    1. LG Incite Touch Screen Replacement, Motherboard: 步骤 7 中的图像 1,3 LG Incite Touch Screen Replacement, Motherboard: 步骤 7 中的图像 2,3 LG Incite Touch Screen Replacement, Motherboard: 步骤 7 中的图像 3,3
      在这个步骤中使用的工具:
      • Use the metal tweezers to gently peel the yellow tab from the left edge of the phone at the two plastic bases.
      • Do not completely remove the tab from the body, it should still be connected to the phone by the orange plastic.
      • Repeat this for the white tab on the opposite side of the phone.
      • This tab also has two plastic bases adhering it to the edge of the phone.
      询问修复机器人
      添加评论
    2. LG Incite Touch Screen Replacement: 步骤 8 中的图像 1,1
      • Insert your plastic opening tool underneath the speaker/camera panel, and gently pry it upwards.
      • Do not fully remove the panel! It should still be attached to the motherboard by a red and black wire.
      询问修复机器人
      添加评论
    3. LG Incite Touch Screen Replacement: 步骤 9 中的图像 1,2 LG Incite Touch Screen Replacement: 步骤 9 中的图像 2,2
      • Use the metal tweezers to gently lift the edge of the maroon tab, it should pop up easily.
      • Do not remove the tab completely, it should still be connected to the phone.
      询问修复机器人
      添加评论
    4. LG Incite Touch Screen Replacement: 步骤 10 中的图像 1,1
      • Insert the plastic opening tool underneath the motherboard towards the bottom edge of the phone and gently pry it from its case.
      • Lift the motherboard and slide it towards you by hand to free it from the phone.
      • The call and end buttons may fall out when the motherboard is removed! Don't lose the buttons.
      询问修复机器人
      添加评论
    1. LG Incite Touch Screen Replacement, Touch Screen: 步骤 11 中的图像 1,1
      在这个步骤中使用的工具:
      • Remove the call and end buttons using the metal tweezers.
      询问修复机器人
      添加评论
    2. LG Incite Touch Screen Replacement: 步骤 12 中的图像 1,1
      • Wedge the plastic opening tool between the screen and sides of the phone.
      • Slide the tool along the edge to loosen the screen.
      • Repeat for the opposite side.
      • Don't completely remove the screen yet to avoid damaging the screen.
      询问修复机器人
      添加评论
    3. LG Incite Touch Screen Replacement: 步骤 13 中的图像 1,1
      • Wedge the plastic opening tool under the screen where the buttons were to loosen it.
      询问修复机器人
      添加评论
    4. LG Incite Touch Screen Replacement: 步骤 14 中的图像 1,2 LG Incite Touch Screen Replacement: 步骤 14 中的图像 2,2
      • Gently peel the touch screen off from the bottom of the phone.
      • Do not damage the yellow tab in the upper right corner of the phone.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
Kimberly Kha
于04/16/13注册
163 声望
创作了5篇指南
团队
Cal Poly, Team 2-18, Maness Spring 2013 Cal Poly, Team 2-18, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G18
4 名成员
创作了29篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 1,588
