跳转到主内容
加入维修社区 - 创建账户
LG Grace Rear Camera Replacement
你所需要的
    1. LG Grace Rear Camera Replacement, Phone Assembly: 步骤 1 中的图像 1,1
      • Find the indentation along the edge of the phone's back and pry open with your nail. A pry tool may help if you have short nails but shouldn't be necessary.
      询问修复机器人
      添加评论
    2. LG Grace Rear Camera Replacement: 步骤 2 中的图像 1,1
      • Pull the battery out of the back of the phone. A small indent is present to allow you to pry it out but you may also just flip the phone over and strike it gently against your palm.
      询问修复机器人
      添加评论
    3. LG Grace Rear Camera Replacement: 步骤 3 中的图像 1,2 LG Grace Rear Camera Replacement: 步骤 3 中的图像 2,2
      • Unscrew all of the screws now visible on the back panel of the phone--11 in total. A #00 Phillips screwdriver works here.
      • The screws are M1.3 and 3 mm long.
      询问修复机器人
      添加评论
    4. LG Grace Rear Camera Replacement: 步骤 4 中的图像 1,2 LG Grace Rear Camera Replacement: 步骤 4 中的图像 2,2
      • Insert the Jimmy into the small gap between the edge of the phone screen and body. Gently pry until it pops loose then remove jimmy and use your hands to slowly pry the body away from the screen
      询问修复机器人
      添加评论
    1. LG Grace Rear Camera Replacement, Rear Camera: 步骤 5 中的图像 1,1
      • Locate the pin connection for the camera, noted by red box in the guide photo.
      • Gently lift the camera up while pulling away from connection; it should detach with minimal effort.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 50
总计 365
