跳转到主内容
加入维修社区 - 创建账户
LG G6 USB-C Port Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
    1. LG G6 USB-C Port Replacement, iOpener Heating: 步骤 1 中的图像 1,2 LG G6 USB-C Port Replacement, iOpener Heating: 步骤 1 中的图像 2,2
      • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
      • Place the iOpener in the center of the microwave.
      • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
      添加评论
    2. LG G6 USB-C Port Replacement: 步骤 2 中的图像 1,1
      • Heat the iOpener for thirty seconds.
      • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
      • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
      • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
      • Never touch the iOpener if it appears swollen.
      • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
      添加评论
    3. LG G6 USB-C Port Replacement: 步骤 3 中的图像 1,1
      • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
      • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
      添加评论
    4. LG G6 USB-C Port Replacement, Alternate iOpener heating method: 步骤 4 中的图像 1,2 LG G6 USB-C Port Replacement, Alternate iOpener heating method: 步骤 4 中的图像 2,2
      • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
      • Fill a pot or pan with enough water to fully submerge an iOpener.
      • Heat the water to a boil. Turn off the heat.
      • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
      • Use tongs to extract the heated iOpener from the hot water.
      • Thoroughly dry the iOpener with a towel.
      • The iOpener will be very hot, so be careful to hold it only by the end tabs.
      • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
      添加评论
    1. LG G6 USB-C Port Replacement, Battery: 步骤 5 中的图像 1,1
      • Apply the heated iOpener to the edge of the phone for about 2 minutes.
      询问修复机器人
      添加评论
    2. LG G6 USB-C Port Replacement: 步骤 6 中的图像 1,3 LG G6 USB-C Port Replacement: 步骤 6 中的图像 2,3 LG G6 USB-C Port Replacement: 步骤 6 中的图像 3,3
      在这个步骤中使用的工具:
      Plastic Cards
      $2.99
      • When the back panel is heated, apply the suction cup close to a corner of the phone. Lift up and insert a halberd spudger or opening pick under the rear glass.
      • Slide the blade of the Halberd spudger along the edge of the phone to separate the adhesive.
      • Follow around the edge of the phone, and use an opening pick or other tool (such as a plastic card) to keep already opened portions from re-adhering.
      询问修复机器人
      添加评论
    3. LG G6 USB-C Port Replacement: 步骤 7 中的图像 1,2 LG G6 USB-C Port Replacement: 步骤 7 中的图像 2,2
      • Using a Philips 000 bit, remove 11 screws from the highlighted locations.
      询问修复机器人
      添加评论
    4. LG G6 USB-C Port Replacement: 步骤 8 中的图像 1,2 LG G6 USB-C Port Replacement: 步骤 8 中的图像 2,2
      • With the screws removed, remove the lower frame components, followed by the upper mid-frame. Both components can be removed with a little prying.
      询问修复机器人
      添加评论
    5. LG G6 USB-C Port Replacement: 步骤 9 中的图像 1,1
      • Begin battery removal by very gently prying off the power ribbon with a plastic card or a nylon spudger.
      添加评论
    6. LG G6 USB-C Port Replacement: 步骤 10 中的图像 1,3 LG G6 USB-C Port Replacement: 步骤 10 中的图像 2,3 LG G6 USB-C Port Replacement: 步骤 10 中的图像 3,3
      • Firmly pull the blue tab. Be careful not to bend the battery as you pull it away from the adhesive.
      • Do not use a knife as you may pierce the battery.
      添加评论
    1. LG G6 USB-C Port Replacement, Motherboard: 步骤 11 中的图像 1,2 LG G6 USB-C Port Replacement, Motherboard: 步骤 11 中的图像 2,2
      在这个步骤中使用的工具:
      • Locate the sim card tray release mechanism on the right edge.
      • Using the tweezers, or similar thin and rigid tool, push in the release button and pull out the sim card tray.
      询问修复机器人
      添加评论
    2. LG G6 USB-C Port Replacement: 步骤 12 中的图像 1,3 LG G6 USB-C Port Replacement: 步骤 12 中的图像 2,3 LG G6 USB-C Port Replacement: 步骤 12 中的图像 3,3
      • Gently pry off the two connectors at the bottom of the phone.
      • Pry off the tape covering the vibrator.
      询问修复机器人
      添加评论
    3. LG G6 USB-C Port Replacement: 步骤 13 中的图像 1,2 LG G6 USB-C Port Replacement: 步骤 13 中的图像 2,2
      • The motherboard is now removable by gently lifting.
      • Upon removal of the motherboard, the small plastic sim card tray release mechanism will be loose and may get lost.
      询问修复机器人
      添加评论
    1. LG G6 USB-C Port Replacement, USB-C Port: 步骤 14 中的图像 1,2 LG G6 USB-C Port Replacement, USB-C Port: 步骤 14 中的图像 2,2
      • Gently pry the USB-c port assembly out of the frame.
      添加评论
结论
取消:我没有完成这个指南。
8等其他人完成本指南。
David Pugliese
于09/26/17注册
1,156 声望
创作了4篇指南
团队
USF Tampa, Team S2-G6, Passmore Fall 2017 USF Tampa, Team S2-G6, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S2G6
4 名成员
创作了46篇指南
2指南评论
what size tape did you use?
Miguel “CharlieMike” Dias - 回复 分享
I skipped removing the main board and was able to remove the port by just lifting the PCB up a little. I also did not remove the battery. just disconnected it. was able the slide out and in the USB port with no trouble or damage.
tenchi50 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 10,120
