跳转到主内容
加入维修社区 - 创建账户
LG G6 Motherboard Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. LG G6 Motherboard Replacement, iOpener Heating: 步骤 1 中的图像 1,2 LG G6 Motherboard Replacement, iOpener Heating: 步骤 1 中的图像 2,2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    添加评论
  2. LG G6 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    添加评论
  3. LG G6 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    添加评论
  4. LG G6 Motherboard Replacement, Alternate iOpener heating method: 步骤 4 中的图像 1,2 LG G6 Motherboard Replacement, Alternate iOpener heating method: 步骤 4 中的图像 2,2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
    添加评论
  5. LG G6 Motherboard Replacement, Battery: 步骤 5 中的图像 1,1
    • Apply the heated iOpener to the edge of the phone for about 2 minutes.
    询问修复机器人
    添加评论
  6. LG G6 Motherboard Replacement: 步骤 6 中的图像 1,3 LG G6 Motherboard Replacement: 步骤 6 中的图像 2,3 LG G6 Motherboard Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • When the back panel is heated, apply the suction cup close to a corner of the phone. Lift up and insert a halberd spudger or opening pick under the rear glass.
    • Slide the blade of the Halberd spudger along the edge of the phone to separate the adhesive.
    • Follow around the edge of the phone, and use an opening pick or other tool (such as a plastic card) to keep already opened portions from re-adhering.
    询问修复机器人
    添加评论
  7. LG G6 Motherboard Replacement: 步骤 7 中的图像 1,2 LG G6 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Using a Philips 000 bit, remove 11 screws from the highlighted locations.
    询问修复机器人
    添加评论
  8. LG G6 Motherboard Replacement: 步骤 8 中的图像 1,2 LG G6 Motherboard Replacement: 步骤 8 中的图像 2,2
    • With the screws removed, remove the lower frame components, followed by the upper mid-frame. Both components can be removed with a little prying.
    询问修复机器人
    添加评论
  9. LG G6 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Begin battery removal by very gently prying off the power ribbon with a plastic card or a nylon spudger.
    添加评论
  10. LG G6 Motherboard Replacement: 步骤 10 中的图像 1,3 LG G6 Motherboard Replacement: 步骤 10 中的图像 2,3 LG G6 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Firmly pull the blue tab. Be careful not to bend the battery as you pull it away from the adhesive.
    • Do not use a knife as you may pierce the battery.
    添加评论
  11. LG G6 Motherboard Replacement, Motherboard: 步骤 11 中的图像 1,2 LG G6 Motherboard Replacement, Motherboard: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    • Locate the sim card tray release mechanism on the right edge.
    • Using the tweezers, or similar thin and rigid tool, push in the release button and pull out the sim card tray.
    询问修复机器人
    添加评论
  12. LG G6 Motherboard Replacement: 步骤 12 中的图像 1,3 LG G6 Motherboard Replacement: 步骤 12 中的图像 2,3 LG G6 Motherboard Replacement: 步骤 12 中的图像 3,3
    • Gently pry off the two connectors at the bottom of the phone.
    • Pry off the tape covering the vibrator.
    询问修复机器人
    添加评论
  13. LG G6 Motherboard Replacement: 步骤 13 中的图像 1,2 LG G6 Motherboard Replacement: 步骤 13 中的图像 2,2
    • The motherboard is now removable by gently lifting.
    • Upon removal of the motherboard, the small plastic sim card tray release mechanism will be loose and may get lost.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
David Pugliese
于09/26/17注册
1,156 声望
创作了4篇指南
团队
USF Tampa, Team S2-G6, Passmore Fall 2017 USF Tampa, Team S2-G6, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S2G6
4 名成员
创作了16篇指南
4指南评论
Hi where i can find mainborad for lg g6 h870
Zaid Nashwan - 回复 分享
i found one on ebay
Greg - 回复 分享
How much access to the SIM Reader does this give you? A customer has broken his SIM Tray and there is a part stuck inside, will removing the board allow me to reach this or would I be removing it for no reason?
Any response appreciated, ty.
RDCharlton - 回复 分享
very good detail
Greg - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 41
总计 8,079
