跳转到主内容
加入维修社区 - 创建账户
LG G4 Rear Camera Replacement
你所需要的
  1. LG G4 Rear Camera Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Make sure the phone is powered off.
    • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
    询问修复机器人
    添加评论
  2. LG G4 Rear Camera Replacement: 步骤 2 中的图像 1,2 LG G4 Rear Camera Replacement: 步骤 2 中的图像 2,2
    • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
    询问修复机器人
    添加评论
  3. LG G4 Rear Camera Replacement: 步骤 3 中的图像 1,3 LG G4 Rear Camera Replacement: 步骤 3 中的图像 2,3 LG G4 Rear Camera Replacement: 步骤 3 中的图像 3,3
    • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
    询问修复机器人
    添加评论
  4. LG G4 Rear Camera Replacement: 步骤 4 中的图像 1,3 LG G4 Rear Camera Replacement: 步骤 4 中的图像 2,3 LG G4 Rear Camera Replacement: 步骤 4 中的图像 3,3
    • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
    • Detach the cover with your fingers
    询问修复机器人
    添加评论
  5. LG G4 Rear Camera Replacement, Motherboard: 步骤 5 中的图像 1,2 LG G4 Rear Camera Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
    • Front-facing camera connector.
    • Rear-facing camera connector.
    • Digitizer connector.
    • The rear-facing camera may be held down to the frame with two sided tape. Try to move the camera with the spudger prior to lifting the motherboard If it does not budge, use the same tool to pry it from the frame to avoid damaging the connector cable in the next step.
    添加评论
  6. LG G4 Rear Camera Replacement: 步骤 6 中的图像 1,2 LG G4 Rear Camera Replacement: 步骤 6 中的图像 2,2
    • Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
    添加评论
  7. LG G4 Rear Camera Replacement, Rear Camera: 步骤 7 中的图像 1,2 LG G4 Rear Camera Replacement, Rear Camera: 步骤 7 中的图像 2,2
    • Gently wedge the plastic opening tool under the ribbon where the rear camera cable is connected, and slowly lift up to detach the cable from the mother board.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
18等其他人完成本指南。
团队
USF Tampa, Team 16-5, Wollert Fall 2015 USF Tampa, Team 16-5, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G5
4 名成员
创作了24篇指南
17指南评论
I preformed this replacement on my LG G4 and found it to be very easy. However, between Steps 5 and 6, I will note a Warning...My camera was firmly attached to the frame with double sided tape. I simply removed the cable connector for the camera prior to lifting the Motherboard off of the frame (Step 6) and then pried the camera off of the frame using the spudger tool. I was able to reuse the tape on the replacement camera.
Gavin McMorrow - 回复 分享
If i power on the phone with the module removed, will it cause any shorting or damage?
shawnlee3010 - 回复 分享
I just did this last night. Phone works great but now My camera does not work.. Any tips
John Gregory - 回复 分享
Also noticed my flash doesn't work anymore. Proximity sensor stopped working and the ability to tap and wake the screen doesn't work either... Any help would be much appreciated
Ordered the part from this website and my phone doesn't recognize the new part. I had to reinstall the old broken camera for it to recognize.
Chelsea Ryan - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 53
总计 17,651
