跳转到主内容
加入维修社区 - 创建账户
LG G3 Rear Facing Camera Replacement
你所需要的
  1. LG G3 Rear Facing Camera Replacement, Back Cover: 步骤 1 中的图像 1,2 LG G3 Rear Facing Camera Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
    询问修复机器人
    添加评论
  2. LG G3 Rear Facing Camera Replacement: 步骤 2 中的图像 1,2 LG G3 Rear Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
    询问修复机器人
    添加评论
  3. LG G3 Rear Facing Camera Replacement, Battery: 步骤 3 中的图像 1,2 LG G3 Rear Facing Camera Replacement, Battery: 步骤 3 中的图像 2,2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    询问修复机器人
    添加评论
  4. LG G3 Rear Facing Camera Replacement: 步骤 4 中的图像 1,2 LG G3 Rear Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Lift the battery out of its recess and remove it.
    询问修复机器人
    添加评论
  5. LG G3 Rear Facing Camera Replacement, Loudspeaker: 步骤 5 中的图像 1,1
    • Remove the four Phillips #00 screws (4 mm length).
    添加评论
  6. LG G3 Rear Facing Camera Replacement: 步骤 6 中的图像 1,2 LG G3 Rear Facing Camera Replacement: 步骤 6 中的图像 2,2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
    询问修复机器人
    添加评论
  7. LG G3 Rear Facing Camera Replacement: 步骤 7 中的图像 1,3 LG G3 Rear Facing Camera Replacement: 步骤 7 中的图像 2,3 LG G3 Rear Facing Camera Replacement: 步骤 7 中的图像 3,3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
    询问修复机器人
    添加评论
  8. LG G3 Rear Facing Camera Replacement, Motherboard Cover Assembly: 步骤 8 中的图像 1,1
    • Remove the eight Phillips #00 screws (4 mm length).
    询问修复机器人
    添加评论
  9. LG G3 Rear Facing Camera Replacement: 步骤 9 中的图像 1,3 LG G3 Rear Facing Camera Replacement: 步骤 9 中的图像 2,3 LG G3 Rear Facing Camera Replacement: 步骤 9 中的图像 3,3
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
    询问修复机器人
    添加评论
  10. LG G3 Rear Facing Camera Replacement: 步骤 10 中的图像 1,3 LG G3 Rear Facing Camera Replacement: 步骤 10 中的图像 2,3 LG G3 Rear Facing Camera Replacement: 步骤 10 中的图像 3,3
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
    询问修复机器人
    添加评论
  11. LG G3 Rear Facing Camera Replacement, Motherboard: 步骤 11 中的图像 1,2 LG G3 Rear Facing Camera Replacement, Motherboard: 步骤 11 中的图像 2,2
    • Use a spudger to pry up and disconnect the display flex cable.
    询问修复机器人
    添加评论
  12. LG G3 Rear Facing Camera Replacement: 步骤 12 中的图像 1,2 LG G3 Rear Facing Camera Replacement: 步骤 12 中的图像 2,2
    • Use a spudger to pry up and disconnect the digitizer flex cable.
    询问修复机器人
    添加评论
  13. LG G3 Rear Facing Camera Replacement: 步骤 13 中的图像 1,2 LG G3 Rear Facing Camera Replacement: 步骤 13 中的图像 2,2
    • Use a spudger to pry up and disconnect the rear camera flex cable.
    询问修复机器人
    添加评论
  14. LG G3 Rear Facing Camera Replacement: 步骤 14 中的图像 1,2 LG G3 Rear Facing Camera Replacement: 步骤 14 中的图像 2,2
    • Use a spudger to pry up and disconnect the front camera flex cable.
    询问修复机器人
    添加评论
  15. LG G3 Rear Facing Camera Replacement: 步骤 15 中的图像 1,2 LG G3 Rear Facing Camera Replacement: 步骤 15 中的图像 2,2
    • During these next few steps, make sure to avoid damaging the flex cables you disconnected.
    • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
    询问修复机器人
    添加评论
  16. LG G3 Rear Facing Camera Replacement: 步骤 16 中的图像 1,2 LG G3 Rear Facing Camera Replacement: 步骤 16 中的图像 2,2
    • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
    询问修复机器人
    添加评论
  17. LG G3 Rear Facing Camera Replacement: 步骤 17 中的图像 1,2 LG G3 Rear Facing Camera Replacement: 步骤 17 中的图像 2,2
    • Grab the top section of the motherboard and carefully lift it out of the phone.
    询问修复机器人
    添加评论
  18. LG G3 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 18 中的图像 1,2 LG G3 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 18 中的图像 2,2
    • Take the plastic opening tool and remove the rear-facing camera by wedging it into the sides and lifting up
    • The rear-facing camera is kept in place with a double-sided tape, so it may take some time and effort to get it out. Attack it from all sides
    询问修复机器人
    添加评论
  19. LG G3 Rear Facing Camera Replacement: 步骤 19 中的图像 1,1
    • Remove the old rear-facing camera
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
26等其他人完成本指南。
Shannon
于10/15/14注册
1,613 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-3, Duarte Fall 2014 UMass Dartmouth, Team 1-3, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S1G3
4 名成员
创作了16篇指南
7指南评论
perfect. Camera had stopped functioning on my G3 (due to some clumsiness on my part). Followed the steps and disconnect camera ribbon, then reconnected and reassembled. Now all functioning perfectly.
Andy Corps - 回复 分享
how was it not functioning? Mine suddenly wont even detect that there is a back camera and I am debating whether to try this and risk ruining the phone or just spending the extra cash and having it done professionally since I can't get a new one until april.
Claire Robbins - 回复 分享
Mine the camera started crashing 'unfortunately camera stopped' but the selfie cam worked. Reset did nothing have to try this.
Gad Mugane - 回复 分享
Will the phone work with out the camera in it?
Mike Kizer - 回复 分享
Excellent guide.    Bad auto focus, replaced -> works !
Would add in step 6, top panel is held on by small plastic tabs on the edges.
As with all electronic dis/assembly, make sure take appropriate anti-static precautions.
Jonathan Ling - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 47
总计 21,218
