跳转到主内容
LG G3 Loudspeaker Replacement
你所需要的
  1. LG G3 Loudspeaker Replacement, Back Cover: 步骤 1 中的图像 1,2 LG G3 Loudspeaker Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Loudspeaker Replacement: 步骤 2 中的图像 1,2 LG G3 Loudspeaker Replacement: 步骤 2 中的图像 2,2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Loudspeaker Replacement, Battery: 步骤 3 中的图像 1,2 LG G3 Loudspeaker Replacement, Battery: 步骤 3 中的图像 2,2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Loudspeaker Replacement: 步骤 4 中的图像 1,2 LG G3 Loudspeaker Replacement: 步骤 4 中的图像 2,2
    • Lift the battery out of its recess and remove it.
  5. LG G3 Loudspeaker Replacement, Loudspeaker: 步骤 5 中的图像 1,1
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Loudspeaker Replacement: 步骤 6 中的图像 1,2 LG G3 Loudspeaker Replacement: 步骤 6 中的图像 2,2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Loudspeaker Replacement: 步骤 7 中的图像 1,3 LG G3 Loudspeaker Replacement: 步骤 7 中的图像 2,3 LG G3 Loudspeaker Replacement: 步骤 7 中的图像 3,3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
结论
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
8等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
210,026 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
141 名成员
创作了17,895篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 14
总计 14,227
