跳转到主内容
LG G3 Battery Replacement
你所需要的
  1. LG G3 Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 LG G3 Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Battery Replacement: 步骤 2 中的图像 1,2 LG G3 Battery Replacement: 步骤 2 中的图像 2,2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Battery Replacement, Battery: 步骤 3 中的图像 1,2 LG G3 Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Battery Replacement: 步骤 4 中的图像 1,2 LG G3 Battery Replacement: 步骤 4 中的图像 2,2
    • Lift the battery out of its recess and remove it.
结论
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
21等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
203,362 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
一条评论
Thank you very much!
ItayDigital - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 22
总计 17,573
