跳转到主内容
加入维修社区 - 创建账户
LG G Watch Spring Bar Pin Replacement
你所需要的
    1. LG G Watch Spring Bar Pin Replacement, Wristband: 步骤 1 中的图像 1,1
      在这个步骤中使用的工具:
      • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
      • Be prepared to apply some pressure with your fingers to perform the following action.
      • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
      • Grasp the exposed shoulder with the tweezers to perform the next step.
      添加评论
    2. LG G Watch Spring Bar Pin Replacement: 步骤 2 中的图像 1,2 LG G Watch Spring Bar Pin Replacement: 步骤 2 中的图像 2,2
      • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
      • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
      • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
      • Repeat steps 1 and 2 for the other wristband.
      询问修复机器人
      添加评论
    1. LG G Watch Spring Bar Pin Replacement, Spring Bar Pin: 步骤 3 中的图像 1,1
      • Slide the spring bar pin out of the wristband.
      • Repeat this step for the other wristband.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Geoff Wacker
于09/30/13注册
92,929 声望
创作了88篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 34
总计 1,380
