跳转到主内容
加入维修社区 - 创建账户
LG G Watch R Battery Replacement Replacement
你所需要的
    1. LG G Watch R Battery Replacement Replacement, Back Case: 步骤 1 中的图像 1,2 LG G Watch R Battery Replacement Replacement, Back Case: 步骤 1 中的图像 2,2
      • Power off your watch before disassembling it.
      • Place the watch upside down on a hard surface so that its back case is facing upright.
      • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
      添加评论
    2. LG G Watch R Battery Replacement Replacement: 步骤 2 中的图像 1,1
      • Use a plastic opening tool to pry open the back case from both sides of the watch.
      询问修复机器人
      添加评论
    3. LG G Watch R Battery Replacement Replacement: 步骤 3 中的图像 1,1
      • Remove the back case.
      询问修复机器人
      添加评论
    1. LG G Watch R Battery Replacement Replacement, Motherboard: 步骤 4 中的图像 1,2 LG G Watch R Battery Replacement Replacement, Motherboard: 步骤 4 中的图像 2,2
      • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
      添加评论
    2. LG G Watch R Battery Replacement Replacement: 步骤 5 中的图像 1,2 LG G Watch R Battery Replacement Replacement: 步骤 5 中的图像 2,2
      • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
      添加评论
    3. LG G Watch R Battery Replacement Replacement: 步骤 6 中的图像 1,1
      • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
      询问修复机器人
      添加评论
    1. LG G Watch R Battery Replacement Replacement, Battery Replacement: 步骤 7 中的图像 1,1
      • Use a plastic opening tool to pry the battery out of the device.
      • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
      添加评论
结论
取消:我没有完成这个指南。
71等其他人完成本指南。
团队
USF Tampa, Team 1-1, Remmell Fall 2015 USF Tampa, Team 1-1, Remmell Fall 2015 的会员
USFT-REMMELL-F15S1G1
5 名成员
创作了24篇指南
13指南评论
The question is where i can find such battery ?
obada abu alhiga - 回复 分享
It did help, small correction - Use a T4 instead of T5 screw driver
Suyog Patki - 回复 分享
On my G Watch R the T5 screw driver perfektly fits.
igor-sweet - 回复 分享
I second the fonejoy link, got it delivered from them very quickly. And I also second what Suyog said regarding the Torx screwdriver, on my own watch I needed a T4, the T5 didn't work, but I had a set so I was okay.
Mike - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 85
总计 31,724
