跳转到主内容
加入维修社区 - 创建账户
LG Front Load Washing Machine Inlet Valve Assembly Replacement
你所需要的
  1. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Safety Precautions: 步骤 1 中的图像 1,2 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Safety Precautions: 步骤 1 中的图像 2,2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    添加评论
  2. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the top panel: 步骤 2 中的图像 1,3 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the top panel: 步骤 2 中的图像 2,3 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the top panel: 步骤 2 中的图像 3,3
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
    询问修复机器人
    添加评论
  3. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the top panel: 步骤 3 中的图像 1,2 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the top panel: 步骤 3 中的图像 2,2
    • Slide the top panel towards the rear of the device to disconnect its clips.
    询问修复机器人
    添加评论
  4. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 步骤 4 中的图像 1,2 LG Front Load Washing Machine Inlet Valve Assembly Replacement: 步骤 4 中的图像 2,2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
    询问修复机器人
    添加评论
  5. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Inlet valve information: 步骤 5 中的图像 1,3 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Inlet valve information: 步骤 5 中的图像 2,3 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Inlet valve information: 步骤 5 中的图像 3,3
    • To prevent confusion, label each valve and its corresponding hose.
    • You can use masking tape or mark the components themselves.
    • Repeat the labelling procedure for each valve and its corresponding connector.
    询问修复机器人
    添加评论
  6. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Disconnect the inlet valve: 步骤 6 中的图像 1,3 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Disconnect the inlet valve: 步骤 6 中的图像 2,3 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Disconnect the inlet valve: 步骤 6 中的图像 3,3
    • Disconnect the connectors from the inlet valve.
    • Always grip cables by their connectors and not the wires themselves.
    询问修复机器人
    添加评论
  7. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 步骤 7 中的图像 1,1
    • Place a dry rag under the inlet valve to soak up any lingering water.
    询问修复机器人
    添加评论
  8. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 步骤 8 中的图像 1,3 LG Front Load Washing Machine Inlet Valve Assembly Replacement: 步骤 8 中的图像 2,3 LG Front Load Washing Machine Inlet Valve Assembly Replacement: 步骤 8 中的图像 3,3
    • Use slip joint pliers to pinch the inlet valve hose clamp and pull it away from the inlet valve assembly.
    询问修复机器人
    添加评论
  9. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 步骤 9 中的图像 1,2 LG Front Load Washing Machine Inlet Valve Assembly Replacement: 步骤 9 中的图像 2,2
    • Use slip joint pliers to rotate the inlet valve hose back and forth around its connection and loosen it.
    询问修复机器人
    添加评论
  10. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 步骤 10 中的图像 1,2 LG Front Load Washing Machine Inlet Valve Assembly Replacement: 步骤 10 中的图像 2,2
    • Pull the inlet valve hose straight off its connection on the inlet valve assembly.
    询问修复机器人
    添加评论
  11. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 步骤 11 中的图像 1,1
    • Repeat the previous three steps for each remaining hose attached to the inlet valve assembly.
    询问修复机器人
    添加评论
  12. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the filters: 步骤 12 中的图像 1,3 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the filters: 步骤 12 中的图像 2,3 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the filters: 步骤 12 中的图像 3,3
    • If your replacement part comes with filters pre-installed, skip this step.
    • Use needle nose pliers to pull the inlet valve filters straight out of the inlets in the chassis.
    • Remove the filters.
    添加评论
  13. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the inlet valve assembly: 步骤 13 中的图像 1,1
    • Remove the screws securing the inlet valve assembly.
    询问修复机器人
    添加评论
  14. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the inlet valve assembly: 步骤 14 中的图像 1,3 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the inlet valve assembly: 步骤 14 中的图像 2,3 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the inlet valve assembly: 步骤 14 中的图像 3,3
    • Pull the inlet valve assembly straight out of its slot in the chassis to remove it.
    添加评论
结论
Repair didn’t go as planned? Ask our Answers community for help.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Bill Gilbert
于06/30/22注册
40,137 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了28,237篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 62
过去 30 天: 215
总计 6,800
