跳转到主内容
加入维修社区 - 创建账户
LG Front Load Washing Machine Control Panel Replacement
你所需要的
  1. LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: 步骤 1 中的图像 1,2 LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: 步骤 1 中的图像 2,2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    添加评论
  2. LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: 步骤 2 中的图像 1,3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: 步骤 2 中的图像 2,3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: 步骤 2 中的图像 3,3
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
    询问修复机器人
    添加评论
  3. LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: 步骤 3 中的图像 1,2 LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: 步骤 3 中的图像 2,2
    • Slide the top panel towards the rear of the device to disconnect its clips.
    询问修复机器人
    添加评论
  4. LG Front Load Washing Machine Control Panel Replacement: 步骤 4 中的图像 1,2 LG Front Load Washing Machine Control Panel Replacement: 步骤 4 中的图像 2,2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
    询问修复机器人
    添加评论
  5. LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: 步骤 5 中的图像 1,2 LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: 步骤 5 中的图像 2,2
    • Pull the detergent drawer away from the chassis as far as it will go.
    询问修复机器人
    添加评论
  6. LG Front Load Washing Machine Control Panel Replacement: 步骤 6 中的图像 1,3 LG Front Load Washing Machine Control Panel Replacement: 步骤 6 中的图像 2,3 LG Front Load Washing Machine Control Panel Replacement: 步骤 6 中的图像 3,3
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
    询问修复机器人
    添加评论
  7. LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: 步骤 7 中的图像 1,3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: 步骤 7 中的图像 2,3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: 步骤 7 中的图像 3,3
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
    询问修复机器人
    添加评论
  8. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: 步骤 8 中的图像 1,2 LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: 步骤 8 中的图像 2,2
    • Remove the screw(s) securing the control panel.
    添加评论
  9. LG Front Load Washing Machine Control Panel Replacement, Unfasten the detergent dispenser: 步骤 9 中的图像 1,1
    • Remove the screw(s) securing the detergent dispenser.
    询问修复机器人
    添加评论
  10. LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: 步骤 10 中的图像 1,3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: 步骤 10 中的图像 2,3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: 步骤 10 中的图像 3,3
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
    询问修复机器人
    添加评论
  11. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: 步骤 11 中的图像 1,3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: 步骤 11 中的图像 2,3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: 步骤 11 中的图像 3,3
    • Remove the control panel, making sure to thread any cables through the chassis.
    询问修复机器人
    添加评论
  12. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel board: 步骤 12 中的图像 1,1
    • Flip the control panel over.
    • Remove the screw(s) securing the control panel board.
    询问修复机器人
    添加评论
  13. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: 步骤 13 中的图像 1,3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: 步骤 13 中的图像 2,3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: 步骤 13 中的图像 3,3
    • Pull the control panel board out of its slot and remove it.
    询问修复机器人
    添加评论
结论
Repair didn’t go as planned? Ask our Answers community for help.
取消:我没有完成这个指南。
3等其他人完成本指南。
Bill Gilbert
于06/30/22注册
40,137 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了29,508篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 61
过去 30 天: 246
总计 5,484
