跳转到主内容
加入维修社区 - 创建账户
LG Dare Logic Board Replacement
你所需要的
    1. LG Dare Logic Board Replacement, Battery: 步骤 1 中的图像 1,2 LG Dare Logic Board Replacement, Battery: 步骤 1 中的图像 2,2
      • Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
      询问修复机器人
      添加评论
    2. LG Dare Logic Board Replacement: 步骤 2 中的图像 1,3 LG Dare Logic Board Replacement: 步骤 2 中的图像 2,3 LG Dare Logic Board Replacement: 步骤 2 中的图像 3,3
      • Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out.
      询问修复机器人
      添加评论
    1. LG Dare Logic Board Replacement, Logic Board: 步骤 3 中的图像 1,2 LG Dare Logic Board Replacement, Logic Board: 步骤 3 中的图像 2,2
      • Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
      询问修复机器人
      添加评论
    2. LG Dare Logic Board Replacement: 步骤 4 中的图像 1,3 LG Dare Logic Board Replacement: 步骤 4 中的图像 2,3 LG Dare Logic Board Replacement: 步骤 4 中的图像 3,3
      • Lift the back plastic cover off by moving the opening tool around the edges of the phone.
      • Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
      • The side buttons may fall out when removing the back plastic.
      询问修复机器人
      添加评论
    3. LG Dare Logic Board Replacement: 步骤 5 中的图像 1,3 LG Dare Logic Board Replacement: 步骤 5 中的图像 2,3 LG Dare Logic Board Replacement: 步骤 5 中的图像 3,3
      • Pull off the back plastic panel.
      • Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
      询问修复机器人
      添加评论
    4. LG Dare Logic Board Replacement: 步骤 6 中的图像 1,1
      • Disconnect the three ribbon connectors from the motherboard.
      询问修复机器人
      添加评论
    5. LG Dare Logic Board Replacement: 步骤 7 中的图像 1,3 LG Dare Logic Board Replacement: 步骤 7 中的图像 2,3 LG Dare Logic Board Replacement: 步骤 7 中的图像 3,3
      • Remove the LED.
      • Remove the camera connector.
      • Remove the camera sensor from the logic board. Squeeze the sides of the camera sensor firmly and pull straight up.
      询问修复机器人
      添加评论
    6. LG Dare Logic Board Replacement: 步骤 8 中的图像 1,1
      • Open the USB port cover.
      询问修复机器人
      添加评论
    7. LG Dare Logic Board Replacement: 步骤 9 中的图像 1,3 LG Dare Logic Board Replacement: 步骤 9 中的图像 2,3 LG Dare Logic Board Replacement: 步骤 9 中的图像 3,3
      • Use the opening tool to lift up the green logic board in all areas and remove it.
      • The logic board may require some force to remove because it is taped to the plastic frame.
      • When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
      询问修复机器人
      添加评论
结论
To re-assemble your device, follow these instructions in reverse order.
取消:我没有完成这个指南。
2等其他人完成本指南。
Haoyan Huang
于01/26/12注册
151 声望
创作了4篇指南
团队
Cal Poly, Team 9-4, Regan Winter 2012 Cal Poly, Team 9-4, Regan Winter 2012 的会员
CPSU-REGAN-W12S9G4
5 名成员
创作了45篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 35
总计 2,601
