跳转到主内容
加入维修社区 - 创建账户
LG Dare Digitizer Replacement
你所需要的
  1. LG Dare Digitizer Replacement, Battery: 步骤 1 中的图像 1,2 LG Dare Digitizer Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
    询问修复机器人
    添加评论
  2. LG Dare Digitizer Replacement: 步骤 2 中的图像 1,3 LG Dare Digitizer Replacement: 步骤 2 中的图像 2,3 LG Dare Digitizer Replacement: 步骤 2 中的图像 3,3
    • Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out.
    询问修复机器人
    添加评论
  3. LG Dare Digitizer Replacement, Logic Board: 步骤 3 中的图像 1,2 LG Dare Digitizer Replacement, Logic Board: 步骤 3 中的图像 2,2
    • Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
    询问修复机器人
    添加评论
  4. LG Dare Digitizer Replacement: 步骤 4 中的图像 1,3 LG Dare Digitizer Replacement: 步骤 4 中的图像 2,3 LG Dare Digitizer Replacement: 步骤 4 中的图像 3,3
    • Lift the back plastic cover off by moving the opening tool around the edges of the phone.
    • Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
    • The side buttons may fall out when removing the back plastic.
    询问修复机器人
    添加评论
  5. LG Dare Digitizer Replacement: 步骤 5 中的图像 1,3 LG Dare Digitizer Replacement: 步骤 5 中的图像 2,3 LG Dare Digitizer Replacement: 步骤 5 中的图像 3,3
    • Pull off the back plastic panel.
    • Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
    询问修复机器人
    添加评论
  6. LG Dare Digitizer Replacement: 步骤 6 中的图像 1,1
    • Disconnect the three ribbon connectors from the motherboard.
    询问修复机器人
    添加评论
  7. LG Dare Digitizer Replacement: 步骤 7 中的图像 1,3 LG Dare Digitizer Replacement: 步骤 7 中的图像 2,3 LG Dare Digitizer Replacement: 步骤 7 中的图像 3,3
    • Remove the LED.
    • Remove the camera connector.
    • Remove the camera sensor from the logic board. Squeeze the sides of the camera sensor firmly and pull straight up.
    询问修复机器人
    添加评论
  8. LG Dare Digitizer Replacement: 步骤 8 中的图像 1,1
    • Open the USB port cover.
    询问修复机器人
    添加评论
  9. LG Dare Digitizer Replacement: 步骤 9 中的图像 1,3 LG Dare Digitizer Replacement: 步骤 9 中的图像 2,3 LG Dare Digitizer Replacement: 步骤 9 中的图像 3,3
    • Use the opening tool to lift up the green logic board in all areas and remove it.
    • The logic board may require some force to remove because it is taped to the plastic frame.
    • When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
    询问修复机器人
    添加评论
  10. LG Dare Digitizer Replacement, Earpiece: 步骤 10 中的图像 1,3 LG Dare Digitizer Replacement, Earpiece: 步骤 10 中的图像 2,3 LG Dare Digitizer Replacement, Earpiece: 步骤 10 中的图像 3,3
    • Peel off the gold and green tape near the bottom of the phone.
    • Peel off the blue tape covering the speaker connector.
    • Peel off the gold tape to the left of the earpiece speaker.
    • It is unnecessary to remove the blue and gold tape from the device if the speaker is not being removed.
    询问修复机器人
    添加评论
  11. LG Dare Digitizer Replacement: 步骤 11 中的图像 1,2 LG Dare Digitizer Replacement: 步骤 11 中的图像 2,2
    • Lift up the orange ribbon cable in the bottom left corner of the device.
    • Peel off the small piece of gold tape underneath the orange component back.
    询问修复机器人
    添加评论
  12. LG Dare Digitizer Replacement: 步骤 12 中的图像 1,2 LG Dare Digitizer Replacement: 步骤 12 中的图像 2,2
    • Undo the clips that attach the black plastic strip to the frame of the phone.
    • Pry the plastic strip away from the phone, using an opening tool, until it detaches.
    询问修复机器人
    添加评论
  13. LG Dare Digitizer Replacement: 步骤 13 中的图像 1,2 LG Dare Digitizer Replacement: 步骤 13 中的图像 2,2
    • Pry the button panel from the device, starting where the screen and panel connect, until the panel detaches.
    询问修复机器人
    添加评论
  14. LG Dare Digitizer Replacement: 步骤 14 中的图像 1,2 LG Dare Digitizer Replacement: 步骤 14 中的图像 2,2
    • Rotate the phone upside down with the back facing you.
    • Using your finger to hold the bottom connector in place, use the opening tool to remove the top connector.
    询问修复机器人
    添加评论
  15. LG Dare Digitizer Replacement: 步骤 15 中的图像 1,3 LG Dare Digitizer Replacement: 步骤 15 中的图像 2,3 LG Dare Digitizer Replacement: 步骤 15 中的图像 3,3
    • Using the opening tool, pry the frame from the device, starting at the open edges at the bottom of the device, and working your way around.
    • Do not detach the frame yet.
    询问修复机器人
    添加评论
  16. LG Dare Digitizer Replacement: 步骤 16 中的图像 1,3 LG Dare Digitizer Replacement: 步骤 16 中的图像 2,3 LG Dare Digitizer Replacement: 步骤 16 中的图像 3,3
    • Gently separate the top of the frame from the back of the device, without completely detaching at the bottom, as shown in the third picture.
    询问修复机器人
    添加评论
  17. LG Dare Digitizer Replacement: 步骤 17 中的图像 1,2 LG Dare Digitizer Replacement: 步骤 17 中的图像 2,2
    • Remove both connectors from the frame. Fold back the L-shaped connector and slide the second connector through the hole in the metal frame.
    • Remove the frame from the plastic panel.
    • The next two steps are for earpiece removal only.
    询问修复机器人
    添加评论
  18. LG Dare Digitizer Replacement: 步骤 18 中的图像 1,2 LG Dare Digitizer Replacement: 步骤 18 中的图像 2,2
    • Using the opening tool, pry the orange connector pad that is securing the earpiece to the frame, away from the device, until it detaches.
    • It may be necessary to apply more force to remove the pad because it is taped to the frame.
    询问修复机器人
    添加评论
  19. LG Dare Digitizer Replacement: 步骤 19 中的图像 1,2 LG Dare Digitizer Replacement: 步骤 19 中的图像 2,2
    • Pry the rest of the orange connector pad --on the opposite side of the device-- away from the frame, and carefully remove the entire earpiece.
    询问修复机器人
    添加评论
  20. LG Dare Digitizer Replacement, Screen: 步骤 20 中的图像 1,2 LG Dare Digitizer Replacement, Screen: 步骤 20 中的图像 2,2
    • Lift all four corners of the screen.
    • Being too aggressive could damage the screen.
    询问修复机器人
    添加评论
  21. LG Dare Digitizer Replacement: 步骤 21 中的图像 1,2 LG Dare Digitizer Replacement: 步骤 21 中的图像 2,2
    • Remove the screen from the digitizer.
    询问修复机器人
    添加评论
  22. LG Dare Digitizer Replacement, Digitizer: 步骤 22 中的图像 1,3 LG Dare Digitizer Replacement, Digitizer: 步骤 22 中的图像 2,3 LG Dare Digitizer Replacement, Digitizer: 步骤 22 中的图像 3,3
    • Using the opening tool, carefully pry the digitizer (the black-rimmed piece) away from the silver frame.
    • Remove the digitizer carefully without breaking the connector.
    • Be careful when removing the digitizer because it is glued to the front panel. It may be necessary to apply more force or use a blow dryer to loosen the glue.
    询问修复机器人
    添加评论
  23. LG Dare Digitizer Replacement: 步骤 23 中的图像 1,1
    • Carefully remove the digitizer connector from the plastic frame. There is a slot that the connector slides through.
    询问修复机器人
    添加评论
结论
To re-assemble your device, follow these instructions in reverse order.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Haoyan Huang
于01/26/12注册
151 声望
创作了4篇指南
团队
Cal Poly, Team 9-4, Regan Winter 2012 Cal Poly, Team 9-4, Regan Winter 2012 的会员
CPSU-REGAN-W12S9G4
5 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 29
总计 5,608
