跳转到主内容
加入维修社区 - 创建账户
LG Chocolate Motherboard Replacement
你所需要的
    1. LG Chocolate Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 LG Chocolate Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
      • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
      • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
      询问修复机器人
      添加评论
    1. LG Chocolate Motherboard Replacement, Back Cover: 步骤 2 中的图像 1,1
      • You will need to use a Phillips #00 screwdriver.
      • Remove the four screws located at the corners beneath the battery.
      • Detach the back case from the phone.
      询问修复机器人
      添加评论
    2. LG Chocolate Motherboard Replacement: 步骤 3 中的图像 1,3 LG Chocolate Motherboard Replacement: 步骤 3 中的图像 2,3 LG Chocolate Motherboard Replacement: 步骤 3 中的图像 3,3
      • Take the case off by using a plastic opening tool.
      • Continue using the plastic opening tool around the sides of the device.
      • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
      • The back speaker will be connected to the motherboard.
      • This must be disconnected in order to remove the case.
      询问修复机器人
      添加评论
    1. LG Chocolate Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 LG Chocolate Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
      • Carefully pry the motherboard off of the back case
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Maci Miri
于01/18/13注册
39 声望
创作了3篇指南
团队
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G46
4 名成员
创作了77篇指南
1指南评论
is there any way to get information off of a motherboard with a chargeport that is broken?
Robert Gietzen - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 25
总计 1,212
