跳转到主内容
加入维修社区 - 创建账户
LG Chocolate 3 Rear Case Replacement
你所需要的
    1. LG Chocolate 3 Rear Case Replacement, Battery: 步骤 1 中的图像 1,1
      • Turn the phone off before starting the replacement process.
      • Place the phone face down.
      • Press your finger down on the indentation and slide the back plate off.
      询问修复机器人
      添加评论
    2. LG Chocolate 3 Rear Case Replacement: 步骤 2 中的图像 1,3 LG Chocolate 3 Rear Case Replacement: 步骤 2 中的图像 2,3 LG Chocolate 3 Rear Case Replacement: 步骤 2 中的图像 3,3
      • Using your index finger lift and remove the battery from the phone.
      询问修复机器人
      添加评论
    1. LG Chocolate 3 Rear Case Replacement, Rear Case: 步骤 3 中的图像 1,1
      • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
      • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
      询问修复机器人
      添加评论
    2. LG Chocolate 3 Rear Case Replacement: 步骤 4 中的图像 1,1
      在这个步骤中使用的工具:
      • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
      • If needed, use tweezers to remove loose screws from the recessed holes.
      • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
      询问修复机器人
      添加评论
    3. LG Chocolate 3 Rear Case Replacement: 步骤 5 中的图像 1,2 LG Chocolate 3 Rear Case Replacement: 步骤 5 中的图像 2,2
      • Pull the rear case up using the spudger.
      • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
      • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
      询问修复机器人
      添加评论
    4. LG Chocolate 3 Rear Case Replacement: 步骤 6 中的图像 1,1
      • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
      询问修复机器人
      添加评论
    5. LG Chocolate 3 Rear Case Replacement: 步骤 7 中的图像 1,2 LG Chocolate 3 Rear Case Replacement: 步骤 7 中的图像 2,2
      • Carefully remove the rear case from the phone.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 12-35, Amido Spring 2013 Cal Poly, Team 12-35, Amido Spring 2013 的会员
CPSU-AMIDO-S13S12G35
5 名成员
创作了54篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 17
总计 602
