跳转到主内容
加入维修社区 - 创建账户
LG Chocolate 3 Keypad Replacement
你所需要的
  1. LG Chocolate 3 Keypad Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the phone off before starting the replacement process.
    • Place the phone face down.
    • Press your finger down on the indentation and slide the back plate off.
    询问修复机器人
    添加评论
  2. LG Chocolate 3 Keypad Replacement: 步骤 2 中的图像 1,3 LG Chocolate 3 Keypad Replacement: 步骤 2 中的图像 2,3 LG Chocolate 3 Keypad Replacement: 步骤 2 中的图像 3,3
    • Using your index finger lift and remove the battery from the phone.
    询问修复机器人
    添加评论
  3. LG Chocolate 3 Keypad Replacement, Rear Case: 步骤 3 中的图像 1,1
    • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
    • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
    询问修复机器人
    添加评论
  4. LG Chocolate 3 Keypad Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
    • If needed, use tweezers to remove loose screws from the recessed holes.
    • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
    询问修复机器人
    添加评论
  5. LG Chocolate 3 Keypad Replacement: 步骤 5 中的图像 1,2 LG Chocolate 3 Keypad Replacement: 步骤 5 中的图像 2,2
    • Pull the rear case up using the spudger.
    • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
    • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
    询问修复机器人
    添加评论
  6. LG Chocolate 3 Keypad Replacement: 步骤 6 中的图像 1,1
    • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
    询问修复机器人
    添加评论
  7. LG Chocolate 3 Keypad Replacement: 步骤 7 中的图像 1,2 LG Chocolate 3 Keypad Replacement: 步骤 7 中的图像 2,2
    • Carefully remove the rear case from the phone.
    询问修复机器人
    添加评论
  8. LG Chocolate 3 Keypad Replacement, Side Buttons: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to remove the music button found on the side of the phone.
    询问修复机器人
    添加评论
  9. LG Chocolate 3 Keypad Replacement: 步骤 9 中的图像 1,2 LG Chocolate 3 Keypad Replacement: 步骤 9 中的图像 2,2
    • Use tweezers to remove the volume control buttons on the opposite side of the phone.
    询问修复机器人
    添加评论
  10. LG Chocolate 3 Keypad Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Use the flat end of the spudger to lift the orange display data cable.
    询问修复机器人
    添加评论
  11. LG Chocolate 3 Keypad Replacement: 步骤 11 中的图像 1,2 LG Chocolate 3 Keypad Replacement: 步骤 11 中的图像 2,2
    • Carefully insert the plastic opening tool between the motherboard and the back of the phone.
    询问修复机器人
    添加评论
  12. LG Chocolate 3 Keypad Replacement: 步骤 12 中的图像 1,2 LG Chocolate 3 Keypad Replacement: 步骤 12 中的图像 2,2
    • Use your thumb and index finger to carefully lift and separate the motherboard from the back of the phone.
    • Be cautious of the orange display data cable, it may stick to the motherboard.
    • To avoid this, lift the data cable away from the motherboard before removal.
    询问修复机器人
    添加评论
  13. LG Chocolate 3 Keypad Replacement, Keypad: 步骤 13 中的图像 1,1
    • Open the phone.
    • Keep the phone open by keeping a firm grip on the hinges to avoid any damages to the phone.
    询问修复机器人
    添加评论
  14. LG Chocolate 3 Keypad Replacement: 步骤 14 中的图像 1,1
    • Lift the orange data cable up so that it is elevated.
    • Gently use a finger to lift the keypad out.
    询问修复机器人
    添加评论
  15. LG Chocolate 3 Keypad Replacement: 步骤 15 中的图像 1,1
    • Insert the spudger in between the keypad and the phone.
    • Lift the keypad to seperate it from the phone.
    询问修复机器人
    添加评论
  16. LG Chocolate 3 Keypad Replacement: 步骤 16 中的图像 1,2 LG Chocolate 3 Keypad Replacement: 步骤 16 中的图像 2,2
    • Remove the damaged keypad.
    • Insert the replacement keypad.
    • Reassemble the phone after the broken keypad is replaced.
    询问修复机器人
    添加评论
结论
To reassemble this device, follow these instructions in reverse order.
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 12-35, Amido Spring 2013 Cal Poly, Team 12-35, Amido Spring 2013 的会员
CPSU-AMIDO-S13S12G35
5 名成员
创作了24篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 30
总计 804
