跳转到主内容
加入维修社区 - 创建账户
LG CU515 Keypad Replacement
你所需要的
  1. LG CU515 Keypad Replacement, Battery: 步骤 1 中的图像 1,2 LG CU515 Keypad Replacement, Battery: 步骤 1 中的图像 2,2
    • Use your thumb to press down and slide off the back cover of the phone.
    询问修复机器人
    添加评论
  2. LG CU515 Keypad Replacement: 步骤 2 中的图像 1,3 LG CU515 Keypad Replacement: 步骤 2 中的图像 2,3 LG CU515 Keypad Replacement: 步骤 2 中的图像 3,3
    • Take out the battery by levering it out towards the bottom of the phone.
    询问修复机器人
    添加评论
  3. LG CU515 Keypad Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
    询问修复机器人
    添加评论
  4. LG CU515 Keypad Replacement: 步骤 4 中的图像 1,1
    • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
    询问修复机器人
    添加评论
  5. LG CU515 Keypad Replacement: 步骤 5 中的图像 1,3 LG CU515 Keypad Replacement: 步骤 5 中的图像 2,3 LG CU515 Keypad Replacement: 步骤 5 中的图像 3,3
    • Push the spudger into the crack separating the two pieces of the phone.
    • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
    • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
    • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
    询问修复机器人
    添加评论
  6. LG CU515 Keypad Replacement: 步骤 6 中的图像 1,1
    • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
    询问修复机器人
    添加评论
  7. LG CU515 Keypad Replacement: 步骤 7 中的图像 1,1
    • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
    询问修复机器人
    添加评论
  8. LG CU515 Keypad Replacement: 步骤 8 中的图像 1,1
    • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
    • Replace the motherboard with a new one.
    询问修复机器人
    添加评论
  9. LG CU515 Keypad Replacement, Keypad: 步骤 9 中的图像 1,1
    • Push keypad up and out of the phone casing until they separate.
    • Replace with new keypad.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 21-55, Johann Spring 2013 Cal Poly, Team 21-55, Johann Spring 2013 的会员
CPSU-JOHANN-S13S21G55
4 名成员
创作了26篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 32
总计 523
