跳转到主内容
加入维修社区 - 创建账户
LG BP220 Motherboard Replacement
你所需要的
  1. LG BP220 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 LG BP220 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Ensure the device is unplugged to prevent shocks.
    • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
    • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
    询问修复机器人
    添加评论
  2. LG BP220 Motherboard Replacement: 步骤 2 中的图像 1,3 LG BP220 Motherboard Replacement: 步骤 2 中的图像 2,3 LG BP220 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Unhinge the tabs that attach the front panel to the unit:
    • Two tabs on the disc drive
    • Two tabs on the left and right side of the player
    • Be careful when handling these tabs. They are very fragile and can be easily broken.
    • Three tabs on the underside of the player
    • Pull panel away from case.
    • If the panel does not come off right away, be sure to check if tabs have inadvertently switched back to their locked position.
    询问修复机器人
    添加评论
  3. LG BP220 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
    询问修复机器人
    添加评论
  4. LG BP220 Motherboard Replacement: 步骤 4 中的图像 1,2 LG BP220 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
    • With the front side facing you lift the front of disc drive, slide it toward you and pull out to remove.
    询问修复机器人
    添加评论
  5. LG BP220 Motherboard Replacement: 步骤 5 中的图像 1,3 LG BP220 Motherboard Replacement: 步骤 5 中的图像 2,3 LG BP220 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Detach the power supply cord from the brown motherboard by pushing the locking clip on the connector, and pulling out.
    • The connector may be difficult to remove. Wiggling it while pulling out may help release it.
    • Remove the power cord from the panel by carefully sliding it upwards from its seating.
    询问修复机器人
    添加评论
  6. LG BP220 Motherboard Replacement: 步骤 6 中的图像 1,2 LG BP220 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the two black 3/16” Phillips #2 screws from the backside of the player.
    • One screw inbetween the audio/video jacks
    • One screw to the bottom right of the audio/video jacks
    • With the backside facing you, pull the bottom of the panel towards you and lift to remove it.
    询问修复机器人
    添加评论
  7. LG BP220 Motherboard Replacement: 步骤 7 中的图像 1,2 LG BP220 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Handle the motherboards with care. They are fragile.
    • Beware of the capacitors as they may shock you when touched.
    • Remove the the two silver 3/16” Phillips #2 screws from the green motherboard.
    • Remove the one black 3/16” Phillips #2 screw from the brown motherboard
    • Use both hands to carefully lift the motherboard unit away from the player.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
Bart Quicho
于01/13/15注册
520 声望
创作了3篇指南
团队
UW Tacoma, Team 1-1, Rose Winter 2015 UW Tacoma, Team 1-1, Rose Winter 2015 的会员
UWT-ROSE-W15S1G1
4 名成员
创作了6篇指南
1指南评论
I need Ic htc lm37102 which is on this lg motherboard. How can i get that. I am not able to find
Email Id abhishek.mishra171983@gmail.com
Please let me know if you have this rgulator ic on my email id.
Thnx
Abhishek
Abhishek Mishra - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 59
总计 5,342
