简介
No prior knowledge needed! Be sure to unplug the device before beginning this guide to avoid electrical shock and damage to yourself and the device.
你所需要的
Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
Use the PH2 (or similar) screw driver to remove the two 12mm screws holding the clear restraining brace.
Remove the restraining brace from the machine base.
