简介
If the image is broken or hazy when looking through the viewfinder of your Kodak Signet 35, then the beamsplitter may be broken or dirty. This guide will show you how to remove it for cleaning or replacing. Before following these steps, make sure you have all the necessary tools, as well as enough time to disassemble and reassemble the device with the proper care.
你所需要的
在这个步骤中使用的工具:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Using the 2.5mm flathead screwdriver, remove both 2.8mm flathead screws that hold the wind and rewind dials in place. Then, remove the washer located underneath each dial.
2等其他人完成本指南。
1指南评论
I feel like the beamsplitter's position can change a great deal depending on how lose the arm is and after cleaning/repair it definitely shifts. How does one position it properly?
I just cleaned mine and now I see two triangles at the bottom of the viewfinder (used to see nothing because the glass elements were all very dirty).
