跳转到主内容
Kodak EasyShare CD82 LCD Display Screen Replacement
你所需要的
  1. Kodak EasyShare CD82 LCD Display Screen Replacement, LCD Screen: 步骤 1 中的图像 1,3 Kodak EasyShare CD82 LCD Display Screen Replacement, LCD Screen: 步骤 1 中的图像 2,3 Kodak EasyShare CD82 LCD Display Screen Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Remove the batteries and the memory card from the device.
    • Remove the 2 screws located at the bottom of the device.
  2. Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 2 中的图像 1,3 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 2 中的图像 2,3 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 2 中的图像 3,3
    • Remove the 2 screws on the side, to the left of the camera lens.
    • Remove the 2 screws on the side, to the right of the camera lens.
    • Pry the casing from the device starting at the battery compartment and following the seem around the camera.
  3. Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 3 中的图像 1,3 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 3 中的图像 2,3 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 3 中的图像 3,3
    • Remove the front panel from the device first, then remove the back panel.
    • Do not remove the LCD screen from the device once it becomes visible.
  4. Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 4 中的图像 1,3 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 4 中的图像 2,3 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 4 中的图像 3,3
    • Flip the LCD screen away from the top of the device to reveal the ribbon cable.
    • This is water damage the has afflicted the camera.
    • Remove the 3 screws from the LCD screen holder.
    • Pry the screen holder from the circuit board connector.
  5. Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 5 中的图像 1,2 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Disconnect the logic board from the right side of the frame.
    • Remove the small ribbon cable that is connecting the button panel to the logic board, using a small pair of tweezers or hemostat.
    • Remove the screw on the top right side of the device.
  6. Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 6 中的图像 1,2 Kodak EasyShare CD82 LCD Display Screen Replacement: 步骤 6 中的图像 2,2
    • Open the connector and move the black clip into the upward position, freeing the cable. Remove the LCD screen and the holder.
    • While the camera is disassembled, use isopropyl alcohol to remove rust and clean the device.
    • Follow these steps in reverse order to reassemble. The device should be fully functional upon completion.
结论
2等其他人完成本指南。
oldturkey03
于09/29/10注册
836,440 声望
创作了123篇指南
1指南评论
Is there any repair for Kodak CD80 easy share camera…..as my camera is not working
Januchowdary - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 1,713
