跳转到主内容
加入维修社区 - 创建账户
Kodak EasyShare C713 Lens Replacement
你所需要的
    1. Kodak EasyShare C713 Lens Replacement, Batteries: 步骤 1 中的图像 1,1
      • Use your finger tip to slide battery cover door away from the center of the camera.
      • The battery door should spring open.
      • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
      添加评论
    2. Kodak EasyShare C713 Lens Replacement: 步骤 2 中的图像 1,1
      • Remove the old batteries.
      询问修复机器人
      添加评论
    1. Kodak EasyShare C713 Lens Replacement, Outer Case: 步骤 3 中的图像 1,3 Kodak EasyShare C713 Lens Replacement, Outer Case: 步骤 3 中的图像 2,3 Kodak EasyShare C713 Lens Replacement, Outer Case: 步骤 3 中的图像 3,3
      • Remove the seven screws from the outer case with a Phillips #00.
      • All screws are 4.45mm.
      • There are 2 screws on the port side.
      • There are 2 screws on starboard side.
      • There are 3 screws on the bottom.
      询问修复机器人
      添加评论
    2. Kodak EasyShare C713 Lens Replacement: 步骤 4 中的图像 1,3 Kodak EasyShare C713 Lens Replacement: 步骤 4 中的图像 2,3 Kodak EasyShare C713 Lens Replacement: 步骤 4 中的图像 3,3
      • Make sure the battery cap is "up".
      • Pull the outer case off with your hands.
      询问修复机器人
      添加评论
    1. Kodak EasyShare C713 Lens Replacement, LCD: 步骤 5 中的图像 1,1
      • The LCD screen is hinged at the bottom.
      • Put your thumb in the upper right corner of the LCD screen.
      • Pull the LCD screen out of its outer case with your thumb.
      询问修复机器人
      添加评论
    2. Kodak EasyShare C713 Lens Replacement: 步骤 6 中的图像 1,1
      • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
      询问修复机器人
      添加评论
    3. Kodak EasyShare C713 Lens Replacement: 步骤 7 中的图像 1,2 Kodak EasyShare C713 Lens Replacement: 步骤 7 中的图像 2,2
      • Desolder the two points.
      • One on the port side.
      • One on the bottom.
      询问修复机器人
      添加评论
    4. Kodak EasyShare C713 Lens Replacement: 步骤 8 中的图像 1,1
      • After desoldering the LCD casing, just use your fingers to carefully remove it.
      询问修复机器人
      添加评论
    5. Kodak EasyShare C713 Lens Replacement: 步骤 9 中的图像 1,1
      • Flip up the black tab on the bottom of the LCD screen with a fingertip.
      询问修复机器人
      添加评论
    6. Kodak EasyShare C713 Lens Replacement: 步骤 10 中的图像 1,1
      • Remove the LCD ribbon cable from inside the black tab.
      询问修复机器人
      添加评论
    1. Kodak EasyShare C713 Lens Replacement, Lens: 步骤 11 中的图像 1,1
      • Using a fingertip, flip the black tab near the top of the camera.
      • Remove the ribbon connector from inside the black tab.
      询问修复机器人
      添加评论
    2. Kodak EasyShare C713 Lens Replacement: 步骤 12 中的图像 1,1
      • Remove the remaining eight 4.1mm screws on the back with the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    3. Kodak EasyShare C713 Lens Replacement: 步骤 13 中的图像 1,1
      • Desolder the upper points.
      • There is a series of solder points in a rectangular area in the upper middle of the camera.
      • There is a large solder point in the upper right.
      询问修复机器人
      添加评论
    4. Kodak EasyShare C713 Lens Replacement: 步骤 14 中的图像 1,1
      • Turn the camera over.
      • Remove the silver 2.2mm battery cap screw.
      询问修复机器人
      添加评论
    5. Kodak EasyShare C713 Lens Replacement: 步骤 15 中的图像 1,2 Kodak EasyShare C713 Lens Replacement: 步骤 15 中的图像 2,2
      • Pry the capacitor out of its holder on the bottom of the camera with your fingers.
      询问修复机器人
      添加评论
    6. Kodak EasyShare C713 Lens Replacement: 步骤 16 中的图像 1,3 Kodak EasyShare C713 Lens Replacement: 步骤 16 中的图像 2,3 Kodak EasyShare C713 Lens Replacement: 步骤 16 中的图像 3,3
      • Remove the lens assembly with your fingers.
      • You may need to wiggle it back and forth until it comes loose.
      • Do not touch the marked areas. This will cause the camera to take blurry pictures.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 26-19, Regan Spring 2010 Cal Poly, Team 26-19, Regan Spring 2010 的会员
CPSU-REGAN-S10S26G19
4 名成员
创作了21篇指南
1指南评论
why didn't you mention to discharge the capacitor, its stored charge is pretty high & dangerous
richard - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 52
总计 7,879
