跳转到主内容
加入维修社区 - 创建账户
Kobo Mini Disassembly
你所需要的
  1. Kobo Mini Disassembly, Kobo Mini Disassembly: 步骤 1 中的图像 1,2 Kobo Mini Disassembly, Kobo Mini Disassembly: 步骤 1 中的图像 2,2
    • Pull on the corner to remove the cover.
    询问修复机器人
    添加评论
  2. Kobo Mini Disassembly: 步骤 2 中的图像 1,1
    • Remove the six screws.
    • Remove the back of the device.
    询问修复机器人
    添加评论
  3. Kobo Mini Disassembly: 步骤 3 中的图像 1,1
    • Remove the four screws from the mother board.
    • Remove the screen connector and the battery connector.
    • Remove the micro SD card.
    • Remove the motherboard from the chassis.
    询问修复机器人
    添加评论
  4. Kobo Mini Disassembly: 步骤 4 中的图像 1,2 Kobo Mini Disassembly: 步骤 4 中的图像 2,2
    • Remove the four screws from the screen frame.
    • Remove the screen
    询问修复机器人
    添加评论
  5. Kobo Mini Disassembly: 步骤 5 中的图像 1,1
    • And we finally finished.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
3等其他人完成本指南。
9指南评论
Just a quick note, I noticed that the SD card in the teardown is a 4gb one. The Kobo Mini has only 2gb of storage. There's just under 2gb of unpartitioned space. You can use a partition manager to extend out the last partition to fill the card, and get close to 4gb of space.
There's a guide over on Mobile Read: https://www.mobileread.com/forums/showth...
Stephanie Raccoon - 回复 分享
Yes I think
Gabriel Bédard - 回复 分享
Thanks for the teardown! See https://www.mobileread.com/forums/showth... and https://wiki.mobileread.com/wiki/Kobo_Mi... for more disassembly advice and information about the components used.
I would be concerned about the reliability of the 4GB micro SD cards when extended to use the full unpartitioned space. While I could imagine a situation where 4GB cards were used due to unavailability of 2GB cards, there doesn’t seem to be a good reason to only format them to 2GB unless they were only guaranteed to reliably hold 2GB of data. In other words, I wonder if they were originally 4GB cards that failed some QA test and were only rated for use as 2GB capacity cards.
David Boddie - 回复 分享
How do you remove the battery connector? Simply pull? Remove the black little things on the sides in some way?
jasonhayden - 回复 分享
Yes you just need to pull it from the motherboard
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 26
过去 30 天: 146
总计 7,590
