跳转到主内容
加入维修社区 - 创建账户
Kobo Clara HD Repairs
你所需要的
    1. Kobo Clara HD Repairs, Before starting: 步骤 1 中的图像 1,1
      • To power off your device, hold down the power button until the "Powered off" screen appears as shown.
      询问修复机器人
      添加评论
    2. Kobo Clara HD Repairs, Back cover: 步骤 2 中的图像 1,3 Kobo Clara HD Repairs, Back cover: 步骤 2 中的图像 2,3 Kobo Clara HD Repairs, Back cover: 步骤 2 中的图像 3,3
      • Stick a plastic spudger into the gap between the front bezel and the back cover.
      • The back cover is held on by small plastic notches.
      • Slide the spudger along the seam to release the back cover.
      • Pry all the way around until the back cover pops free.
      询问修复机器人
      添加评论
    3. Kobo Clara HD Repairs, Battery: 步骤 3 中的图像 1,3 Kobo Clara HD Repairs, Battery: 步骤 3 中的图像 2,3 Kobo Clara HD Repairs, Battery: 步骤 3 中的图像 3,3
      • Gently pry up the white battery connector to pop it out of its bracket.
      询问修复机器人
      添加评论
    4. Kobo Clara HD Repairs, Screen connectors: 步骤 4 中的图像 1,3 Kobo Clara HD Repairs, Screen connectors: 步骤 4 中的图像 2,3 Kobo Clara HD Repairs, Screen connectors: 步骤 4 中的图像 3,3
      • Flip up the black tabs on the three ZIF connectors to release the ribbon cables.
      • The smallest connector, under the big cable, has the black locking tab facing towards the cable.
      • Slide the ribbon cables out of the ZIF sockets.
      询问修复机器人
      添加评论
    5. Kobo Clara HD Repairs, Battery: 步骤 5 中的图像 1,2 Kobo Clara HD Repairs, Battery: 步骤 5 中的图像 2,2
      • The battery is stuck down with strong double-sided tape and secured by a bracket moulded into the back cover.
      询问修复机器人
      添加评论
    6. Kobo Clara HD Repairs, Storage: 步骤 6 中的图像 1,2 Kobo Clara HD Repairs, Storage: 步骤 6 中的图像 2,2
      • All the storage is on a microSD card hidden inside the device.
      • Swap it out at your own risk.
      询问修复机器人
      添加评论
    7. Kobo Clara HD Repairs, Logic board: 步骤 7 中的图像 1,2 Kobo Clara HD Repairs, Logic board: 步骤 7 中的图像 2,2
      • Use a Phillips #00 screwdriver to remove the 4 screws securing the logic board.
      • Lift the logic board out from the top of the device.
      • There is a black sheet of plastic that sits under the logic board.
      询问修复机器人
      添加评论
    8. Kobo Clara HD Repairs: 步骤 8 中的图像 1,2 Kobo Clara HD Repairs: 步骤 8 中的图像 2,2
      • To reassemble your device, follow these steps in reverse order.
      • Pro tip: when closing the plastic housing, squeeze it shut close to the edges to avoid putting too much pressure on the display.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
3等其他人完成本指南。
Sparky
于03/15/26注册
1,535 声望
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 121
过去 30 天: 448
总计 1,417
