跳转到主内容
加入维修社区 - 创建账户
KitchenAid Professional 600 Worm Gear Replacement
你所需要的
    1. KitchenAid Professional 600 Worm Gear Replacement, Top Cover: 步骤 1 中的图像 1,1
      • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
      • Remove the silver band.
      添加评论
    2. KitchenAid Professional 600 Worm Gear Replacement: 步骤 2 中的图像 1,1
      • Remove the four Phillips #2 screws located around the mixer where the band was removed.
      • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
      询问修复机器人
      添加评论
    3. KitchenAid Professional 600 Worm Gear Replacement: 步骤 3 中的图像 1,1
      • Remove the top of the mixer to reveal the inner parts.
      • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
      询问修复机器人
      添加评论
    1. KitchenAid Professional 600 Worm Gear Replacement, Gear Housing Cover: 步骤 4 中的图像 1,1
      • Remove the 4 Phillips #2 screws connecting the black housing cover to the device.
      • Only one of the screws is seen in the picture. The other three are also located around the black housing cover.
      询问修复机器人
      添加评论
    2. KitchenAid Professional 600 Worm Gear Replacement: 步骤 5 中的图像 1,1
      • Take off the black housing cover.
      询问修复机器人
      添加评论
    1. KitchenAid Professional 600 Worm Gear Replacement, Worm Gear: 步骤 6 中的图像 1,1
      • Remove the Worm Gear.
      • The Worm Gear is the part that is lying horizontal.
      • Remember to apply food safe grease onto your new replacement part before assembling the device back together.
      添加评论
结论
取消:我没有完成这个指南。
9等其他人完成本指南。
Luke
于04/11/16注册
1,380 声望
创作了5篇指南
团队
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016 的会员
CPSU-MANESS-S16S25G4
4 名成员
创作了27篇指南
1指南评论
No tiene ningún tornillo a los lado eso es mentira
Guillermo Perez - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 153
总计 22,880
