跳转到主内容
加入维修社区 - 创建账户
KitchenAid Professional 600 Speed Selector Replacement
你所需要的
    1. KitchenAid Professional 600 Speed Selector Replacement, Top Cover: 步骤 1 中的图像 1,1
      • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
      • Remove the silver band.
      添加评论
    2. KitchenAid Professional 600 Speed Selector Replacement: 步骤 2 中的图像 1,1
      • Remove the four Phillips #2 screws located around the mixer where the band was removed.
      • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
      询问修复机器人
      添加评论
    3. KitchenAid Professional 600 Speed Selector Replacement: 步骤 3 中的图像 1,1
      • Remove the top of the mixer to reveal the inner parts.
      • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
      询问修复机器人
      添加评论
    1. KitchenAid Professional 600 Speed Selector Replacement, Speed Selector: 步骤 4 中的图像 1,1
      • Locate the selector switch.
      • Remove the two Phillips #2 screws holding the selector switch in place.
      询问修复机器人
      添加评论
    2. KitchenAid Professional 600 Speed Selector Replacement: 步骤 5 中的图像 1,3 KitchenAid Professional 600 Speed Selector Replacement: 步骤 5 中的图像 2,3 KitchenAid Professional 600 Speed Selector Replacement: 步骤 5 中的图像 3,3
      • Unplug the cords attaching the drive motor to the switch.
      • We suggest numbering them left from right so they are reattached to the replacement part in the right order.
      添加评论
    3. KitchenAid Professional 600 Speed Selector Replacement: 步骤 6 中的图像 1,1
      • Pull out the Selector Switch.
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016 的会员
CPSU-MANESS-S16S25G4
4 名成员
创作了27篇指南
8指南评论
The instructions are to unplug the cords from the motor but the removed selector switch pictured shows the cords were removed from the selector switch. Is there a way to remove the cords from the selector switch without breaking them? donmilo@yahoo.com
Don Singleton - 回复 分享
The replacement part looks like a major part in the mixer and probably costs a bundle like most replacement parts… sometimes deems the replacement “not worthy” to repair!
It’s like a car that cost $25K but, all its parts if you buy them separately, it will cost you $150K !!!
david almogi - 回复 分享
The speed selector MSRP is $89.99 and can be found on places like eBay for $35-60. For only needing some simple tools and a little time, this fix saves you from the cost of buying a new one. These are designed to be repaired/refurbished.
Rachel Johnson - 回复 分享
When the speed selector is replaced, what is the rpm for “stir”?
everything is working, but it still seems too fast at 120rpm and I can’t see a difference between speeds 6, 8, & 10.
Jessica - 回复 分享
The advice about kitchenaid600 switch was good. The form to get me able to say thanks was not.
What thehelldoyouwant - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 145
总计 14,767
