跳转到主内容
加入维修社区 - 创建账户
KitchenAid Professional 600 Power Cord Replacement
你所需要的
    1. KitchenAid Professional 600 Power Cord Replacement, Top Cover: 步骤 1 中的图像 1,1
      • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
      • Remove the silver band.
      添加评论
    2. KitchenAid Professional 600 Power Cord Replacement: 步骤 2 中的图像 1,1
      • Remove the four Phillips #2 screws located around the mixer where the band was removed.
      • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
      询问修复机器人
      添加评论
    3. KitchenAid Professional 600 Power Cord Replacement: 步骤 3 中的图像 1,1
      • Remove the top of the mixer to reveal the inner parts.
      • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
      询问修复机器人
      添加评论
    1. KitchenAid Professional 600 Power Cord Replacement, Speed Selector: 步骤 4 中的图像 1,1
      • Locate the selector switch.
      • Remove the two Phillips #2 screws holding the selector switch in place.
      询问修复机器人
      添加评论
    2. KitchenAid Professional 600 Power Cord Replacement: 步骤 5 中的图像 1,3 KitchenAid Professional 600 Power Cord Replacement: 步骤 5 中的图像 2,3 KitchenAid Professional 600 Power Cord Replacement: 步骤 5 中的图像 3,3
      • Unplug the cords attaching the drive motor to the switch.
      • We suggest numbering them left from right so they are reattached to the replacement part in the right order.
      添加评论
    3. KitchenAid Professional 600 Power Cord Replacement: 步骤 6 中的图像 1,1
      • Pull out the Selector Switch.
      添加评论
    1. KitchenAid Professional 600 Power Cord Replacement, Drive Motor: 步骤 7 中的图像 1,1
      • Remove the two Phillips #2 screws holding the motor in place, located near the fan at the back of the motor.
      • The picture only shows one of the screws. The other screw is located on the exact opposite side of the motor.
      询问修复机器人
      添加评论
    2. KitchenAid Professional 600 Power Cord Replacement: 步骤 8 中的图像 1,1
      • Pull upward to remove the motor.
      添加评论
    1. KitchenAid Professional 600 Power Cord Replacement, Power Cord: 步骤 9 中的图像 1,1
      • Remove the Phillips #2 screw attaching the green grounding wire to the frame of the mixer.
      询问修复机器人
      添加评论
    2. KitchenAid Professional 600 Power Cord Replacement: 步骤 10 中的图像 1,1
      • Remove the three Phillips #2 screws that connect the top portion of the mixer to the "neck" of the mixer.
      询问修复机器人
      添加评论
    3. KitchenAid Professional 600 Power Cord Replacement: 步骤 11 中的图像 1,1
      • Remove the top portion of the mixer from the "neck" of the mixer.
      • This will make removing the power cord much easier.
      询问修复机器人
      添加评论
    4. KitchenAid Professional 600 Power Cord Replacement: 步骤 12 中的图像 1,1
      • You can now remove the power cord from the mixer.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Luke
于04/11/16注册
1,380 声望
创作了5篇指南
团队
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016 的会员
CPSU-MANESS-S16S25G4
4 名成员
创作了27篇指南
2指南评论
So helpful thank you. I've got my mixer cord changer and the mixer is working now. Unfortunately there's always only one speed, high. Any suggestions?
Britter C - 回复 分享
Any idea where I can buy the power cord itself?
Jaeger Amzallag - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 74
总计 7,433
