跳转到主内容
加入维修社区 - 创建账户
KitchenAid KSM150PSER Speed Control Plate Replacement
你所需要的
  1. KitchenAid KSM150PSER Speed Control Plate Replacement, Speed Control Plate: 步骤 1 中的图像 1,2 KitchenAid KSM150PSER Speed Control Plate Replacement, Speed Control Plate: 步骤 1 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling back and up on the cover.
    询问修复机器人
    添加评论
  2. KitchenAid KSM150PSER Speed Control Plate Replacement: 步骤 2 中的图像 1,3 KitchenAid KSM150PSER Speed Control Plate Replacement: 步骤 2 中的图像 2,3 KitchenAid KSM150PSER Speed Control Plate Replacement: 步骤 2 中的图像 3,3
    • Using a Phillips #2 screwdriver, remove the 5mm screws holding the trimband to the top housing by rotating them counterclockwise.
    • Pull the trimband off the housing by grabbing each side and pulling it off the front.
    询问修复机器人
    添加评论
  3. KitchenAid KSM150PSER Speed Control Plate Replacement: 步骤 3 中的图像 1,3 KitchenAid KSM150PSER Speed Control Plate Replacement: 步骤 3 中的图像 2,3 KitchenAid KSM150PSER Speed Control Plate Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Using a Phillips #2 screwdriver, remove the 12mm screw by holding the grounding wire in place and rotating it counterclockwise.
    • Using pliers or tweezers, remove the connectors attached to the speed control plate.
    询问修复机器人
    添加评论
  4. KitchenAid KSM150PSER Speed Control Plate Replacement: 步骤 4 中的图像 1,2 KitchenAid KSM150PSER Speed Control Plate Replacement: 步骤 4 中的图像 2,2
    • Remove the seal from the back of the mixer. Then unhook the spring from the bottom of the speed control plate by using tweezers and pulling it back and out of the plate.
    • Take a rag or towel and hook the spring on the towel so that the hook doesn’t spring back inside the mixer.
    添加评论
  5. KitchenAid KSM150PSER Speed Control Plate Replacement: 步骤 5 中的图像 1,2 KitchenAid KSM150PSER Speed Control Plate Replacement: 步骤 5 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the two adjustment screws by rotating them counterclockwise.
    • Before beginning to remove the screws, use a ruler and measure how far the screws are in. These screws determine the speed of the mixer, and not screwing them back in to the same position will change the speed of the mixer.
    添加评论
  6. KitchenAid KSM150PSER Speed Control Plate Replacement: 步骤 6 中的图像 1,1
    • The control plate can now be removed by pulling back on the plate.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
10等其他人完成本指南。
Richa Gadgil
于01/24/18注册
349 声望
撰写一个指南
团队
Cal Poly, Team S2-G5, Livingston Winter 2018 Cal Poly, Team S2-G5, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S2G5
4 名成员
创作了16篇指南
1指南评论
Thanks for this, but a quick question, when the mixer is switched off, the metal bar on the back of the speed plate at the bottom, is that supposed to rest on the two prongs that stick out towards the bottom of the inside of the mixer? Thanks.
Mark R (dflipb) - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 41
过去 30 天: 150
总计 24,671
