简介
The power cable connects the power supply to the blender.
你所需要的
Remove the glass container and place the blender upside down on a solid surface.
Remove the four rubber feet using the needle nose pliers.
Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
Slide the knife into the metal loop holding the insulation before the white copper wire, and wiggle it back and forth until it loosens.
Pull the wire out from the metal loop that you loosened.
Repeat this process with the black copper wire.
Using the Phillips #2 screwdriver, remove the #8 Phillips 6mm screw to which the green wire is attached.
