跳转到主内容
加入维修社区 - 创建账户
Kindle Voyage Ambient Light Sensor Replacement
你所需要的
    1. Kindle Voyage Ambient Light Sensor Replacement, Back Panel: 步骤 1 中的图像 1,2 Kindle Voyage Ambient Light Sensor Replacement, Back Panel: 步骤 1 中的图像 2,2
      • Insert a plastic opening tool between the plastic panel shown on the device.
      • Use the tool to pry the plastic away from the device.
      • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
      添加评论
    2. Kindle Voyage Ambient Light Sensor Replacement: 步骤 2 中的图像 1,1
      • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
      添加评论
    3. Kindle Voyage Ambient Light Sensor Replacement: 步骤 3 中的图像 1,3 Kindle Voyage Ambient Light Sensor Replacement: 步骤 3 中的图像 2,3 Kindle Voyage Ambient Light Sensor Replacement: 步骤 3 中的图像 3,3
      • Once the screws are removed, the back panel can slide off the device.
      添加评论
    4. Kindle Voyage Ambient Light Sensor Replacement: 步骤 4 中的图像 1,2 Kindle Voyage Ambient Light Sensor Replacement: 步骤 4 中的图像 2,2
      • Remove the magnetic component with the magnetic head of the aluminum driver.
      添加评论
    1. Kindle Voyage Ambient Light Sensor Replacement, Wifi Antenna: 步骤 5 中的图像 1,2 Kindle Voyage Ambient Light Sensor Replacement, Wifi Antenna: 步骤 5 中的图像 2,2
      • Use an aluminum driver with Phillips head #00 to remove the four 3 mm screws shown in the picture.
      • Use the same driver to remove the two 2.5 mm screws.
      询问修复机器人
      添加评论
    2. Kindle Voyage Ambient Light Sensor Replacement: 步骤 6 中的图像 1,3 Kindle Voyage Ambient Light Sensor Replacement: 步骤 6 中的图像 2,3 Kindle Voyage Ambient Light Sensor Replacement: 步骤 6 中的图像 3,3
      在这个步骤中使用的工具:
      • Using the tweezers, undo the attached clip.
      • Remove the three 3 mm screws holding down the rest of the antenna with an aluminum driver and the Phillips #00 head.
      • You should now be able to simply take the WiFi bar off of the device.
      询问修复机器人
      添加评论
    1. Kindle Voyage Ambient Light Sensor Replacement, Ambient Light Sensor: 步骤 7 中的图像 1,2 Kindle Voyage Ambient Light Sensor Replacement, Ambient Light Sensor: 步骤 7 中的图像 2,2
      在这个步骤中使用的工具:
      • Gently remove the connector to the motherboard using tweezers.
      • Continue to carefully pull the rest of the connector from the adhesive connecting it to the Voyage.
      • Detach sensor from the top using fingers
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Sean Yap
于01/22/15注册
1,508 声望
创作了6篇指南
团队
Cal Poly, Team 19-12, Maness Winter 2015 Cal Poly, Team 19-12, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G12
5 名成员
创作了14篇指南
1指南评论
If i do this wiithout putting the lightsensor back on, can i then use the kindle without light ?
Best regards
Lasse
Beck - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 43
总计 3,175
