跳转到主内容
加入维修社区 - 创建账户
Kindle Touch Screen Replacement
你所需要的
  1. Kindle Touch Screen Replacement, Back Cover: 步骤 1 中的图像 1,3 Kindle Touch Screen Replacement, Back Cover: 步骤 1 中的图像 2,3 Kindle Touch Screen Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
    • Don't pry the clips on the top half of the back panel.
    添加评论
  2. Kindle Touch Screen Replacement: 步骤 2 中的图像 1,2 Kindle Touch Screen Replacement: 步骤 2 中的图像 2,2
    • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
    • Once the top clips release, gently lift the back panel away.
    添加评论
  3. Kindle Touch Screen Replacement, Battery: 步骤 3 中的图像 1,3 Kindle Touch Screen Replacement, Battery: 步骤 3 中的图像 2,3 Kindle Touch Screen Replacement, Battery: 步骤 3 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the five screws.
    询问修复机器人
    添加评论
  4. Kindle Touch Screen Replacement: 步骤 4 中的图像 1,3 Kindle Touch Screen Replacement: 步骤 4 中的图像 2,3 Kindle Touch Screen Replacement: 步骤 4 中的图像 3,3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
    询问修复机器人
    添加评论
  5. Kindle Touch Screen Replacement, Remove the 3G Board: 步骤 5 中的图像 1,3 Kindle Touch Screen Replacement, Remove the 3G Board: 步骤 5 中的图像 2,3 Kindle Touch Screen Replacement, Remove the 3G Board: 步骤 5 中的图像 3,3
    • Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
    • Next, gently lift the 3G assembly with a Spudger or your fingers.
    • This Kindle Touch is the WiFi only model and comes with a plastic placeholder instead of the 3G assembly.
    • Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
    添加评论
  6. Kindle Touch Screen Replacement, Bezel: 步骤 6 中的图像 1,2 Kindle Touch Screen Replacement, Bezel: 步骤 6 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
    询问修复机器人
    添加评论
  7. Kindle Touch Screen Replacement: 步骤 7 中的图像 1,3 Kindle Touch Screen Replacement: 步骤 7 中的图像 2,3 Kindle Touch Screen Replacement: 步骤 7 中的图像 3,3
    • Use the plastic opening tool to pry the bezel from the top and sides
    • The bottom of the bezel will be glued, so be careful when sliding the clips out.
    • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
    询问修复机器人
    添加评论
  8. Kindle Touch Screen Replacement, Rear Casing: 步骤 8 中的图像 1,1
    • Use your Phillips #00 srewdriver to remove the indicated screws.
    • There are three pairs of screws that are each different. The screws on the top corners are 4 mm #00 Phillips screws, the screws on the bottom corners are 2 mm #00 Phillips screws, and the black bottom center screws are 6 mm #00 Phillips screws.
    询问修复机器人
    添加评论
  9. Kindle Touch Screen Replacement: 步骤 9 中的图像 1,2 Kindle Touch Screen Replacement: 步骤 9 中的图像 2,2
    • With the screws removed, gently remove the case from the internals.
    询问修复机器人
    添加评论
  10. Kindle Touch Screen Replacement, Motherboard: 步骤 10 中的图像 1,3 Kindle Touch Screen Replacement, Motherboard: 步骤 10 中的图像 2,3 Kindle Touch Screen Replacement, Motherboard: 步骤 10 中的图像 3,3
    • With the screen facing you, use your heated iOpener or other heating element to loosen the glue holding the WiFi unit to the screen. After 30 seconds, remove the heating element.
    • After the glue is loosened, use a thin tool, like a Spudger or small plastic opening tool, to separate the WiFi unit from the screen.
    询问修复机器人
    添加评论
  11. Kindle Touch Screen Replacement: 步骤 11 中的图像 1,2 Kindle Touch Screen Replacement: 步骤 11 中的图像 2,2
    • With the motherboard facing you, use the pointy end of your Spudger to gently separate the two speaker's connectors.
    • This connector type requires being lifted out of place, not pulled. Accidentally pulling may damage the wires.
    • During reassembly, make sure the speaker's connectors are not pushed behind the motherboard.
    • Use your #00 Phillips Screwdriver to remove the seven 2 mm screws.
    询问修复机器人
    添加评论
  12. Kindle Touch Screen Replacement: 步骤 12 中的图像 1,3 Kindle Touch Screen Replacement: 步骤 12 中的图像 2,3 Kindle Touch Screen Replacement: 步骤 12 中的图像 3,3
    • Use a Spudger to separate the display's connector from the motherboard.
    • Gently remove the motherboard from the display support.
    询问修复机器人
    添加评论
  13. Kindle Touch Screen Replacement, Screen: 步骤 13 中的图像 1,3 Kindle Touch Screen Replacement, Screen: 步骤 13 中的图像 2,3 Kindle Touch Screen Replacement, Screen: 步骤 13 中的图像 3,3
    • Using your Metal Spudger, place the pointy end into the top of the clip.
    • Gently rotate the Spudger and lift the plastic unit to create a gap on the side.
    询问修复机器人
    添加评论
  14. Kindle Touch Screen Replacement: 步骤 14 中的图像 1,2 Kindle Touch Screen Replacement: 步骤 14 中的图像 2,2
    • Use the Spudger in the gap to pry the clip open.
    • Repeat for the other clips.
    询问修复机器人
    添加评论
  15. Kindle Touch Screen Replacement: 步骤 15 中的图像 1,3 Kindle Touch Screen Replacement: 步骤 15 中的图像 2,3 Kindle Touch Screen Replacement: 步骤 15 中的图像 3,3
    • With the clips separated, gently guide the Screen's Motherboard Connector through the hole.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
10等其他人完成本指南。
Adam Yerly
于01/20/15注册
2,043 声望
创作了7篇指南
团队
USF Tampa, Team 19-5, Blackwell Winter 2015 USF Tampa, Team 19-5, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S19G5
3 名成员
创作了8篇指南
6指南评论
I would love to know where I can get the replacement screen. Any links?
Ryan Lee - 回复 分享
Good guide, thanks, finally, if you need to remove the screen itself from the black plastic frame you can do this inserting the spudger carefully between the screen and the black plastic frame and gradually moving it all round the frame. It will help if you put a heated silicon gel pack over each side before trying to release it
John Chapple - 回复 分享
I have a Kindle with half of screen responding to touch
Is the touch incliduded on the screen itself? Will replacing the screen help or is there another way to fix the touch?
Mohd. Nauman Khalid - 回复 分享
No, the touch circuitry is built into the motherboard.
Chris Halliwell - 回复 分享
Where do you buy the screen replacement part for the Kindle Touch?
Andrew Manger - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 70
总计 11,346
